Kraken resells Weefine housings; they are completely different from Divevolk in that they use a Bluetooth connection to the phone inside and an app to interface with, whereas Divevolk SeaTouch series use a flexible membrane to allow you to operate the phone's touchscreen from outside the housing. The Weefine housings also close as a clamshell, whereas Divevolk has a small lid on its short edge, reducing the sealing area. On the other hand, Weefine housings have a vacuum system for the seals, while Divevolk doesn't.Note that Kraken also sells phone housings, including what seems the identical model from Divevolk, but for $50 more.
Ahem: https://www.diversdirect.com/p/kraken-seatouch-4-max-housing/DD161246?sku=DD161246&gad_source=1Kraken resells Weefine housings; they are completely different from Divevolk in that they use a Bluetooth connection to the phone inside and an app to interface with, whereas Divevolk SeaTouch series use a flexible membrane to allow you to operate the phone's touchscreen from outside the housing. The Weefine housings also close as a clamshell, whereas Divevolk has a small lid on its short edge, reducing the sealing area. On the other hand, Weefine housings have a vacuum system for the seals, while Divevolk doesn't.Note that Kraken also sells phone housings, including what seems the identical model from Divevolk, but for $50 more.
No smartphone currently on the market is capable of syncing with a xenon flash, aside from a few models which, I believe, use HSS mode to overcome the lack of a mechanical shutter. There used to be some, way back, for example Nokia 808 PureView and some older HTC phones, back in the Windows Mobile age, but those are long gone. If you want to shoot a phone underwater, you need to use either natural light and color correction, or LED lights in constant or strobe mode. The latter doesn't give you anywhere near the power of a proper xenon strobe, but it also doesn't scare away the fish the way constant lights do.
Ah, I see - but that one isn't even rebranded; just resold at the same price
krakensports.ca
