Is the equivalency of the EF 85 f/1.2 L ii on the GFX 100 ii roughly 68 f/.96?
If not, what is it?
Do you mean, what lens on a GFX do you need to provide the equivalent of an 85mm f/1.2 on FF? If that's what you mean, then to get a GFX lens that provides about the same field of view and subject isolation as an 85mm f/1.2 on FF provides, then the GFX would need a 108mm f/1.5. This is using the compromise of the diagonals to provide equivalence, which may or may not apply, depending on crop.
