G
Graham Meale
Guest
This is called the Ponzo illusion.
They should not be of the same size in the picture (if they are of same physical size). As we learned our brain that thing further away must look smaller, it become weird with a picture when the cars would be of same size no matter of the distance. Then we see them as of different physical size.
When they are no longer in the picture?
Yes it is.This is called the Ponzo illusion.
Yes, I made that point and explained it. It's another lesser optical illusion but for another reason.From the way the vehicles are stacked in this image, my brain still sees them getting progressively larger. The apparent percentage is just decreased.
I've rotated the image, cropped and masked out the background. The cars are clearly the same size. The original image is an optical illusion and a very good one at that.
In this image, the last car still "looks" a little bigger but not as much as before where we were blind-sided by the strong perspective in the road and trees. The reason the last car still looks a little bigger is because the cars are behind one another causing our brain to conclude that it's further away and if it appears the same absolute size, the brain assumed it's bigger.
Not that I've tried it but someone said that bend down and look back between your legs at that horizon moon and it looks normal size. At my age not game to attempt that gymnastic. Maybe it's all about viewing it upside down. Anyone care to try?When the moon is low in the sky, near the horizon, it looks bigger. Much the same illusion.
That was pretty much the reason why I posted that photo (found on Facebook...) here, to point out that sometime we think we saw something that in fact wasn't there.It all proves to me that vision is 10% eyeball plus 90% brain.
In this case "I imaging" as opposed to the currently popular "AI imaging".
Or you can get those glasses that flip what you see upside down.Not that I've tried it but someone said that bend down and look back between your legs at that horizon moon and it looks normal size. At my age not game to attempt that gymnastic. Maybe it's all about viewing it upside down. Anyone care to try?When the moon is low in the sky, near the horizon, it looks bigger. Much the same illusion.
Exactly! If you've ever been on jury duty and listened to eye-witness accounts, you'd wonder if they were even on the same planet.That was pretty much the reason why I posted that photo (found on Facebook...) here, to point out that sometime we think we saw something that in fact wasn't there.It all proves to me that vision is 10% eyeball plus 90% brain.
Not my photo, as I already stated, and how it was done has been explained already. Anyway in the original photo there was only the van in the middle. The author of the illusion copied and pasted that van in front and at the back .Different focal lengths used?
It's an excellent illusion, thanks for posting it. What greatly helps this illusion is the fact that the offset parking on a road in the way the vans are positioned wouldn't happen in real life. All the vans would be parked directly behind each other and you wouldn't be able to see the fronts of the 2nd and third vans. I couldn't think of a way of maneuvering the back two vans behind the first van that way so I've placed them side by side. The back van is the one on the right. The van on the left is the first van which I haven't touched in any way. I cloned the missing parts of the 2nd and third vans from the 1st van. As can be seen and already proven beyond doubt, they are all the same size and if anything, to my eyes the 1st van now looks ever so slightly bigger than the other two!
What is more mind-boggling is that you would expect the front-car to be larger than the one in back, (especially if shot with a UWA).
That' the part that my brain is still chewing on. I look at the image presented and wonder why the vehicle further away isn't smaller than the closest vehicle. Photo is backwards in relation to what we see in the real world. If objects are the same physical size, they are going to appear smaller with distance, not larger. ????What is more mind-boggling is that you would expect the front-car to be larger than the one in back, (especially if shot with a UWA).
