I have both the Voigt 23mm 1.2 and Fuji 23mm 2. I'm happy with the Voigt--fun to use. I was expecting it to not match the Fuji away from the center and I'm well aware of the field curvature.
Did a direct comparison with my Fuji 23mm 2. See below. These are screenshots with both lenses at F8 --that's usually where I would have the lens for landscapes and care about detail. I'm looking down from a nearly 3 story window on flat ground both lenses on the same plane of focus.
The selection is midway out from center (at the very center the two lenses are indistinguishable). And of course this is zoomed into 100%. At anything except very large print sizes I'm not sure that the difference would matter.
Still, if anyone has done any direct comparisons with the two lenses (or the 23 1.4 or even a Fuji zoom or something else comparable) is the difference observable here roughly what you would expect from mid-frame on for the Voigt? If so, I'm ok with it, just wanting to make sure that my Voigt isn't somehow out of whack.
Note: click on the image and zoom in to see the difference--it's compressed here so not as obvious.
