While playing with my optical spectroscope, I realized that I can cast a rainbow on a sheet on paper with it. This is not its proper use, as you are supposed to look into it to see spectra.
So, I decided to photograph it with my DP3M to see, how well it would render spectrum of sunlight. In my test, sunlight was coming through a pane of glass (aka closed window), and cheap white paper was used to "catch" the spectra.
My set up was weak as I had to align the spectroscope manually to get the rainbow to image properly, while holding a camera with my other hand...
So, ISO320 and all that "good" stuff.
I might redo it more cleanly and with white Teflon tape instead of paper, but this will do for now:
I checked it with a 405+-10nm laser pointer, and the resulting narrow band lands right where violets end on all color images above. So, roughly speaking this cut off point is around 405+-10nm.
I also noticed that there appears to be a lit area past the violet area (B100 shows it well).
My guess is that either:
1) some UV got through the glass, lit up a UV-sensitive dye in the paper. (Such dyes are used to make paper more blue optically). So, this created a glow in the visible parts of the spectrum, but it was imaged where UV would be cast by the spectroscope.
2) Alternatively, DP3M can capture some UV past 390nm.
