Color management question. Considered the PC forum but the question may be more generic than to PS.
I want to edit raw images using a camera linear profile and in a color space that uses a gamma 1.0.
I believe I have it working but have a question about PS rendering.
I created a camera linear profile for my Z6 using the Adobe DNG Profile Editor. I removed the hue twists from that resulting profile using dcpTool.
I created a ProPhoto RGB Gamma 1.0 profile in PS via Edit -> Color Settings -> Working Spaces [RGB] (dropdown) -> Custom RGB, set Gamma 1.0, then saved via Working Spaces [RGB] (dropdown) -> Save RGB, restarted PS to see the new profiles.
Loaded a raw into ACR that's spot-metered to the middle gray WB target, selected my Z6 profile, then selected my custom ProPhotoRGB Gamma 1.0 as the encoding color space. When the image loads into PS the histogram is correct - it reflects both the linear camera profile and the absence of ProPhoto's 1/1.8 gamma tonal response curve applied to the image data. However, the rendition of the image in PS appears as if the image is being converted to 1/1.8 or 1/2.2, ie same tonal distribution as an sRGB 1/2.2. Here's an animated demonstration:
Raw image into ACR sRGB vs Linear Gamma 1.0 vs ... (Animation)
The animation has three slides:
- ACR-loaded raw using linear camera profile with sRGB color space
- ACR-loaded raw using linear camera profile with custom ProPhoto RGB w/1.0 gamma
- Same as #2 but the image data reinterpreted as sRGB using Edit -> Assign Profile
