stillviking
Forum Enthusiast
- Messages
- 367
- Reaction score
- 72
I'm looking to find an LP-E6N charger quickly in stock, I only find for LP-E6 in description (Patona, Newell, Hahnel, etc.). Do they work the same?
Thanks!
Thanks!
LP-E6 is the same as LP-E6N and the LP-E6NH, just a little more density in the N and NH versions, so yes, the chargers should be the same. The canon OEM charger is the sane since the LP-E6 was released many years ago.I'm looking to find an LP-E6N charger quickly in stock, I only find for LP-E6 in description (Patona, Newell, Hahnel, etc.). Do they work the same?
Thanks!
I think there is a little more to it than that as (I read that) the LP-E6 does not support the in-camera USB charging feature of the later R-model cameras.LP-E6 is the same as LP-E6N and the LP-E6NH, just a little more density in the N and NH versions,I'm looking to find an LP-E6N charger quickly in stock, I only find for LP-E6 in description (Patona, Newell, Hahnel, etc.). Do they work the same?
Thanks!
What's that got to do with the charger the OP was asking about? But any LP-E6/N/NH battery will work in any of the canon cameras that take the type of battery. I still have an original LP-E6 and it works fine in my R5 as well as using it with an R and several of the 5D's and 7D I had owned. And all those cameras came with the same charger.I think there is a little more to it than that as (I read that) the LP-E6 does not support the in-camera USB charging feature of the later R-model cameras.LP-E6 is the same as LP-E6N and the LP-E6NH, just a little more density in the N and NH versions,I'm looking to find an LP-E6N charger quickly in stock, I only find for LP-E6 in description (Patona, Newell, Hahnel, etc.). Do they work the same?
Thanks!
My reply was not to the OP it was to your statement about the batteries being the same other than their [energy] densityWhat's that got to do with the charger the OP was asking about?I think there is a little more to it than that as (I read that) the LP-E6 does not support the in-camera USB charging feature of the later R-model cameras.LP-E6 is the same as LP-E6N and the LP-E6NH, just a little more density in the N and NH versions,I'm looking to find an LP-E6N charger quickly in stock, I only find for LP-E6 in description (Patona, Newell, Hahnel, etc.). Do they work the same?
Thanks!
so it seems that the LP-E6 is indeed not fully compatible with the R5 features - no internal chargingany LP-E6/N/NH battery will work in any of the canon cameras that take the type of battery. I still have an original LP-E6 and it works fine in my R5 as well as using it with an R and several of the 5D's and 7D I had owned. And all those cameras came with the same charger.
As for in camera charging, That may be due to firmware in the battery to keep from charger an aftermarket battery in camera for whatever reason. Same with needing the NH version to get a full 20FPS on my R5. Or maybe it's just canon trying to convince you HAVE to have the $79 OEM batteries. Just like when the original LP-E6 came out, you needed the OEM battery for the battery level meter to work correctly but it has long been hacked since then with aftermarket batteries.
Dan W was 100% correct in that statement, it had nothing to do with internal charging.My reply was not to the OP it was to your statement about the batteries being the same other than their [energy] densityWhat's that got to do with the charger the OP was asking about?I think there is a little more to it than that as (I read that) the LP-E6 does not support the in-camera USB charging feature of the later R-model cameras.LP-E6 is the same as LP-E6N and the LP-E6NH, just a little more density in the N and NH versions,I'm looking to find an LP-E6N charger quickly in stock, I only find for LP-E6 in description (Patona, Newell, Hahnel, etc.). Do they work the same?
Thanks!
That was not a question in the original post, nor was it brought up in Dan's reply.so it seems that the LP-E6 is indeed not fully compatible with the R5 features - no internal chargingany LP-E6/N/NH battery will work in any of the canon cameras that take the type of battery. I still have an original LP-E6 and it works fine in my R5 as well as using it with an R and several of the 5D's and 7D I had owned. And all those cameras came with the same charger.
nevertheless, my reply was to Dan regarding his statement about the batteries themselves:Dan W was 100% correct in that statement, it had nothing to do with internal charging.My reply was not to the OP it was to your statement about the batteries being the same other than their [energy] densityWhat's that got to do with the charger the OP was asking about?I think there is a little more to it than that as (I read that) the LP-E6 does not support the in-camera USB charging feature of the later R-model cameras.LP-E6 is the same as LP-E6N and the LP-E6NH, just a little more density in the N and NH versions,I'm looking to find an LP-E6N charger quickly in stock, I only find for LP-E6 in description (Patona, Newell, Hahnel, etc.). Do they work the same?
Thanks!
again, I was responding to Dan not the OPThat was not a question in the original post,so it seems that the LP-E6 is indeed not fully compatible with the R5 features - no internal chargingany LP-E6/N/NH battery will work in any of the canon cameras that take the type of battery. I still have an original LP-E6 and it works fine in my R5 as well as using it with an R and several of the 5D's and 7D I had owned. And all those cameras came with the same charger.
But that was exactly the problem with his reply to the OP, he made a statement which omitted that particular difference between the LP-E6 and the other two battery models.nor was it brought up in Dan's reply.
I see, sorry I didn't realize you were simply looking for a point to argue. In-camera charging has nothing to do with anything discussed. I'll bow out of this pointless side conversation. I won't waste your time responding any further.nevertheless, my reply was to Dan regarding his statement about the batteries themselves:Dan W was 100% correct in that statement, it had nothing to do with internal charging.My reply was not to the OP it was to your statement about the batteries being the same other than their [energy] densityWhat's that got to do with the charger the OP was asking about?I think there is a little more to it than that as (I read that) the LP-E6 does not support the in-camera USB charging feature of the later R-model cameras.LP-E6 is the same as LP-E6N and the LP-E6NH, just a little more density in the N and NH versions,I'm looking to find an LP-E6N charger quickly in stock, I only find for LP-E6 in description (Patona, Newell, Hahnel, etc.). Do they work the same?
Thanks!
"LP-E6 is the same as LP-E6N and the LP-E6NH, just a little more density in the N and NH versions"
He didn't say that the LP-E6 is the same as LP-E6N and the LP-E6NH in so far as they can all be charged with the same external charger, he said that they are the same other than their differing energy densities - clearly suggesting that the energy density / capacity is the only difference - which is clearly not the case as one of them can't be charged in the camera.
And the OP didn't ask about energy density or capacity did he, but Dan brought it up and implied that it was the only difference between the batteries.
