TransientEye
Well-known member
I am having quite a painful experience trying to use a Pro 1000 with custom paper. I can see and select the custom paper on the Mac, but not on the printer.
The paper was added via the 'Media Configuration Tool' app on macOS, and this seems to be persistent in that if I quit and restart the app it will fetch the list of papers from the printer correctly.
But on the printer LCD itself, it seems to loose the custom paper definitions. For a while, I could select the paper type from the menu for the manual-feed only (not the top feed), but now this also appears to have disappeared.
If I print from Canon's 'Professional Print and Layout" app, I can correctly set the paper type in the app itself. The printer will warn about a mismatch between the loaded and requested paper type, which clicking ok allows the print to seemingly work with the correct media definitions (although it is hard to be sure of this).
Any ideas why the custom paper type is only selectable on the Mac and not the printer?
