areallygrumpyoldsod
Yes this is the increasing less hidden demand in "we must have a D500 replacement" -- nope we must have a Nikon Z version of R7, but with a 32.5MP DX sized stacked BSI sensor like the Z8/Z9 and the performance of a Z8 all for less than $2.5-3k AND that is ludicrous.A dedicated DX camera like the D500 delivers a greater pixel density than does an FX camera with the same pixel count. Most responses that have mentioned pixel counts are asking for 30+ MP, rather more than the Z7/8/9 can deliver in DX mode.
We all know that Z50 and D500 are functionally very similar - same sensor, except the Z50 has an Expeed 6 chip, far far greatly improved AF, 11 fps not 10. But the D500 had a higher resolution LCD, 1/8000th not 1/4000th, and so on.
Neither have IBIS and anything updated would have USB-C, CFE-B and improved EVF/LCD.
The 397g Z50 is half the weight of the 860g D500 and a little smaller (127x60x94mm -vs- 147x81x115mm) However, BIF/wildlife shooters want IBIS, 2 cards, robustness and at least an EN-EL15 sized battery not just lightness and that means a D500 sized solution not a Z50 sized body - IBIS and battery need space AND the larger grip is essential when shooting with large lenses.My feeling is that a DX body that comes out at the same size as an FX body isn’t quite what is wanted. With mirrorless technology there’s no reason why a DX camera shouldn’t behave and perform in exactly the same way as it’s FX brother, but in a smaller package. The trend is that lighter means smaller.
No casual shooter would naturally buy a D500 and nor would one buy a Z500 -vs- a cheaper, smaller and lighter Z50ii. The Z500 would be for a different market.
The R7 is 132.0 x 90.4 x 91.7 mm and weighs in at 530g - a little under midway between the 860g D500 and 397g Z50. The R7 comes with a 38.4 x 21 x 56.8 mm 79g LP-E6NH battery which has a capacity of 2130 mAh; whereas a similarly sized EN-EL15C is 50x40x20 but heavier weighs 100G and provides 2280 mAh. +21g and 7% more power. However the hot running Expeed 7 eats power.
Some argue that a non-stacked BSI sensor would be a way to deliver a cheaper Z500 -- sure but what would be lost? Blackout free shooting, much lower fps, and much more.SO no I am not in favour, but I suspend judgement until we see what an actual Zf comes with and how it performs -- this is rumoured to be a non-stacked BSI sensor+IBIS with the Expeed 7 chip... but we have to wait to see.
You are correct this is not what is being requested -- BIF shooters who cannot or do not want to pay more than the cost of a 180-600 and certainly would not buy a Z800 want the cheaper higher resolution Z500. However, I am with you the Z8 and Z9 are perfect for me AND yes if I want more reach then I also carry ZTC14.I you are going to make your whole camera range DX with the associated lenses and accessories optimised for DX there is an obvious advantage. I you are going to build the majority of your lenses for FX and produce DX bodies of the same size and weight as FX bodies, where’s the weight advantage? Just add a 1.4x teleconverter to get the same effect? I’m sure that’s not what is being requested.
I contend that Nikon has far far more pressing demands - Z6iii, Z7iii and YES an update to the Z5 and Z50 -- well well before any Z500 -- unless the Z500 is priced at $4500.
areallygrumpyoldsod
Nikon and Hasselblad shooter -- wildlife and and --
https://www.andymillerphoto.co.uk/
https://www.flickr.com/photos/ajm057/
I do not respond to PMs or messages via my website
