things to consider when using 6x4.5 back on RB67
BylineBuddha
Member
hi there follks
when i bought my RB67 i got it with another back, the 6X4.5 one and also the mask for using it.
honesly i havnt got to use it yet.
now im considering to run a test but was wondering,
is there any difference in lens view?
i mean - i only use the 127mm lens which gives me roughly 58mm.
so is there any 'cost' by using a 6x4.5 format ?
thanks in regard
hi there follks
thanks in regard
I’ve used an A16 back on a Hasselblad V series and it pretty much did as you would expect - you got a smaller negative, but 16 of them rather than 12. I didn’t have the mask on the viewfinder so I was guessing the framing. Apart from getting more frames on a roll I don’t really see any advantages, you’ve still got a very big camera to make a 645 negative (and a RB67 would be bigger still).
The entire reason for lugging around such a beast of a camera as the RB67 is the big, glorius negative it shoots. There isn't much reason to use a 6x4.5 back on it, except for the dubious benefit of getting more exposures per roll of film. If that's the goal, go back to 35mm or smaller formats.
I would agree. I have a friend's RB67 on long-term loan, and it's a pain in the butt to use -- but man, those negatives! You do get more shots per roll but still have the difficulty of setting up the RB67 for a photo, which can take a while.
If you're interested in the smaller negative size (and if it isn't cost prohibitive), a Mamiya 645 is a much better solution -- it's a smaller camera and much easier to carry and use. I have (or have access to) a Mamiya RB67, C330 and 645 1000s, and the 645 is my favorite.
Aaron
hi there follks
thanks in regard
You are precropping. The lens is the lens.
DOF and image magnification will be identical, but the frame will be tighter. Like comparing a FF DSLR to an APS-C.
