brucet
Apart from the crop factor what are the disadvantages of using a DX lens on A Z 6ii.
You will be stuck with the DX crop. Hopefully that gives you a desirable angle of view. And the 24MP Z6ii becomes about 10MP, which is OK for a web post or email, but that is pretty low.Apart from the crop factor what are the disadvantages of using a DX lens on A Z 6ii.
Sorry. I should have been more specific. I understand the crop/mp issue. I'm more concerned about any quality issues.You will be stuck with the DX crop. Hopefully that gives you a desirable angle of view. And the 24MP Z6ii becomes about 10MP, which is OK for a web post or email, but that is pretty low.Apart from the crop factor what are the disadvantages of using a DX lens on A Z 6ii.
What quality are you concerned about? That depends on exactly which DX lens you use. And is 10MP sufficient quality? 15 years ago, I used the 12MP D300 and D700 a lot, and 12MP was ok.Sorry. I should have been more specific. I understand the crop/mp issue. I'm more concerned about any quality issues.You will be stuck with the DX crop. Hopefully that gives you a desirable angle of view. And the 24MP Z6ii becomes about 10MP, which is OK for a web post or email, but that is pretty low.Apart from the crop factor what are the disadvantages of using a DX lens on A Z 6ii.
You will also get IQ corresponding to DX camera.Sorry. I should have been more specific. I understand the crop/mp issue. I'm more concerned about any quality issues.You will be stuck with the DX crop. Hopefully that gives you a desirable angle of view. And the 24MP Z6ii becomes about 10MP, which is OK for a web post or email, but that is pretty low.Apart from the crop factor what are the disadvantages of using a DX lens on A Z 6ii.
Thanks. That's the information I was looking for. Is there somewhere I can see tests that show what the IQ loss would be? I'm ok with the 10mp size as long as that is a quality 10mp.You will also get IQ corresponding to DX camera.Sorry. I should have been more specific. I understand the crop/mp issue. I'm more concerned about any quality issues.You will be stuck with the DX crop. Hopefully that gives you a desirable angle of view. And the 24MP Z6ii becomes about 10MP, which is OK for a web post or email, but that is pretty low.Apart from the crop factor what are the disadvantages of using a DX lens on A Z 6ii.
It would be around one stop. Just switch to DX mode and try it by yourself.Thanks. That's the information I was looking for. Is there somewhere I can see tests that show what the IQ loss would be?You will also get IQ corresponding to DX camera.Sorry. I should have been more specific. I understand the crop/mp issue. I'm more concerned about any quality issues.You will be stuck with the DX crop. Hopefully that gives you a desirable angle of view. And the 24MP Z6ii becomes about 10MP, which is OK for a web post or email, but that is pretty low.Apart from the crop factor what are the disadvantages of using a DX lens on A Z 6ii.
I have a DX Tamron 16-300mm lens that I may want to use occasionally on a Z 6ii. The Nikon Z 24-70mm would be my work horse until some money comes my way!!
If you are used to using that DX Tamron on an existing Nikon DX camera then you will get the same IQ as on the DX camera, once you factor in any difference in pixel count.Thanks. That's the information I was looking for. Is there somewhere I can see tests that show what the IQ loss would be? I'm ok with the 10mp size as long as that is a quality 10mp.You will also get IQ corresponding to DX camera.Sorry. I should have been more specific. I understand the crop/mp issue. I'm more concerned about any quality issues.You will be stuck with the DX crop. Hopefully that gives you a desirable angle of view. And the 24MP Z6ii becomes about 10MP, which is OK for a web post or email, but that is pretty low.Apart from the crop factor what are the disadvantages of using a DX lens on A Z 6ii.
Thanks for the work.An informal test. Z6, 24-200 at 150mm, auto exposure.
FX, jpg straight out of camera.
DX, jpg straight out of camera. Auto exposure set it to 1/125 and ISO 640, compared to 1/80 and ISO 400 in FX.
DX crop of the FX image. ( It's slightly shorter vertically.) Comparing side-by-side, zoomed in to 200%, I think the FX crop seems slightly better. But this is a quick, handheld test, not a careful tripod test. Both are perfectly good enough.
