https://www.smallrig.com/SmallRig-FreeBlazer-Heavy-Duty-Carbon-Fiber-Tripod-Kit-3989.html
It is designed for videography, but it looks to be a good choice for still photography as well especially with self-footed telephotos.
These are the specs I think most of us will be interested in
Weight: 5kg / 11lbs
Max height: 197cm / 77.6 inches
Min height: 94cm / 37 inches
For work outdoors, dual spikes at the bottom of each leg are uncovered by removing the standard flat feet.
Load Capacity of fluid damped head: 10kg/ 22lbs with 8kg counterbalance force
Fore/aft Pitch angle range: +90 /-60
built-in 75mm leveling bowl (no center column) with a flat platform with 3/8"-16 threaded stud
The plate receiver for the head works with both standard Mantrotto video plates or DJI R2/ RS 3 /RS 3 plates. (the latter means you won't have to remount the camera on a new plate when moving a camera from being tripod mounted to those DJI R2/ RS 3 /RS 3 handheld gimbals
Price for head and tripod: USD $399.00
I have owned other SmallRig components and havent been disappointed so if this tripod performs in the field does indeed matc its spec'd performanc, this could be an ideal tripod for all but the most heavy-duty demands. What will be looking for is how smooth the tilts and pans are.
Ellis Vener
To see my work, please visit http://www.ellisvener.com
I am on Instagram @EllisVenerStudio
“It's not about the f-stop." -Jay Maisel
"If art is the destination, craft is how you get there." - Robert Fripp
Weight: 5kg / 11lbs
Ellis Vener
