Theses are not my photos.. I saw them on the internet and send them as a few members suggested- as an example of what I try to achieve…I never used LED lights .. and never done “dramatic “ look. Hi
I have several LED lights. I will probably buy several more.
If you are doing stills, and in particular doing black and white, then some lights like the Godox SL200 (or the SL 200 II), or the Aputure Amaran 200d (actually cheaper than the godox, which is a surprise).
They both have a Bowens mount so there are a metric butt ton of inexpensive modifiers that you can throw on to them, including magnum reflectors, beauty dishes, even fresnels, and of course, grids and snoots. (Hmmm... would a combination grid plus snoot be called a Groot???)
Also there are a whole slew of softboxes and octas (although the sample photos you posted looked more like hard light instead of soft light that you would get from octas and softboxes)
A few notes just in general:
For your use, you should avoid bi-color lights and rgb lights. They have less light output than a daylight-balanced light, and since you are shooting in black and white, you won't really need lights that can change the color temperature. Also, gels are a thing.
Secondly, the more expensive lights (Aputure Lightstorm, etc.) have quieter fans (important when shooting video and fan noise can get recorded, not really important for stills) and those more expensive lights have higher color accuracy (again, probably not as crucial for black and white stills).
The other thing is that LED lights are GENERALLY available as LED panels, or as single-point lights (chip-on-board, or known as COB lights). For your needs for "dramatic" lighting, then definitely recommend going with COB lights and avoid the panels for two reasons: 1) Panels generally have less power than COB lights when you compare them dollar for dollar, and 2) It is easier to transform the hard light of a COB in to soft light that it is to transform the soft light of an LED Panel in to hard light.
And again, the sample images you showed look to be hard light.
The two lights I mentioned earlier (Godox SL200 and aputure Amram 200d) are both chip on board (COB) lights, hence easily give you all the hard light you need, and can be easily softened using the numerous inexpensive modifiers that flood the internets.
What Middle School Is Really Like:
