Jacques Cornell
There's nothing "rudimentary" about DxO's profile-based Lens Sharpness. It applies stronger sharpening in areas where a given lens model is known to be softer. Try that with any other app. In my view this is all that's needed for capture sharpening.Whatever capture sharpening is applied by DxO isn't a complete solution, as you note. In fact, DxO has a separate independent sharpening module, which strongly suggests that DxO understands the limitations of whatever sharpening is automatically applied.OTOH, DxO's lens profiles apply excellent capture sharpening. For creative and output sharpening, I rely on Lightroom.Noise reduction and sharpening for detail are two sides of the same coin. While Photolab 6 noise reduction of RAW files is excellent and I use it whereber possible, PL 6 lacks the best sharpening routines.Yes, I'm happy with DxO PhotoLab v6.
Moderately happy with Topaz Denoise AI, but I would only use it on images that I can't process using DeepPRIME (i.e. non-raw images).
For many files the sharpening of Topaz software and in some cases Luminar Neo will provide a better overall result. I print almost exclusively on13x19" and 17x22" papers and occasionally on 17x25".
Sharpening in Photoshop is not the same as Lightroom and Photoshop has no dedicated output sharpening.
Depending on the photo if I want the best quality sharpening, following whatever rudimentary sharpening is applied by DxO
For creative sharpening, DxO's USM combined with U-point local adjustments is pretty versatile.
I used to use PhotoKit Sharpener for output sharpening until I read that much of the tech behind it had been shared by the devs with Adobe and incorporated into Lightroom's output sharpening in the Export module., I will use Topaz or Neo. This is particularly effective for high ISO. I will also do an output sharpening for inkjet printing some photos with either NIK or the old Photokit output sharpener.
"Don't be mean. We don't have to be mean. Because, remember, no matter where you go, there you are." - Buckaroo Banzai
Landscape & Wedding Photographer - Jacques Cornell
Jacques Cornell Photography - landscape, travel, portrait and art reproduction
jacquescornell.photography
Happening Photos - Event Photography in New York City
Event Photography in New York City and Around the World - conferences, sales meetings, fundraisers and more.
happening.photos
