I get blur images due to cam shake for using low shutter speed such as 1/60 handheld. I have to set a low shutter speed as the lighting condition is not ideal.
A friend told me that if my camera can do high fps (e.g. using electronic shutter), it will compensate for the motion blur due to low shutter speed. I haven't try that out yet.
Is this true?
Your friend's advice is off the mark. A high frame rate or frames per second (fps) does not improve freezing of movement or the steadiness of the shot. It's all about shutter speed and steadiness of the camera & lens.
I assume you're photographing a static subject. If the subject is moving, there's no getting around using a fast enough shutter speed to freeze movement, assuming that's your goal.
If you're doing handheld photography of a static subject, does the camera or the lens have built-in stabilization? If so, activate stabilization to help with handholding a steady shot. If the camera and lens do not have stabilization, work on improving your handhold technique. If you can brace yourself against a solid surface or sit and brace your elbows against your legs, that will help. Also, taking a deep breath and slowly exhaling while shooting can help.
I lieu of stabilization or improved handhold technique, use a tripod.
A high frame rate is helpful if you're photographing a fast-moving subject and hoping to capture a specific moment, body position, or facial expression. It can also hello if you're panning to follow movement at a slow shutter speed and hoping for one frame in which something in the frame is well-resolved while everything else looks blurry.
Good luck.
