Lumix S5IIX vs Canon R8
wonderschlang
Active member
Tuebingen, DE
Now that the R8 has hit the market with 4k60p uncropped (without cooling system) under $2k, do you think, that Pana will maybe bring that feature to the S5IIX and even the S5II? Would it technically be possible?
Unfortunately the Lumix S5ii's sensor isn't fast enough to do 4k 60 without a crop. Panasonic said that if they were to put in a faster reading sensor, it would raise the price of the S5ii. It's the same with the S5iix. Still I would probably go for the S5ii over the R8. The only thing imo the R8 has over the S5ii is the faster burst rate and the faster sensor but apart from that I think the S5ii is better in every other way
I believe the R8 is a tech demo camera. It’s purpose is to give people a limited demo of what the R6II does. It is effectively an EOS RP with an R6II sensor inside. It does not have a proper mechanical shutter (efcs only), and the 40fps burst speeds are limited by the much smaller buffer, and single SD media slot. It is also very likely to overheat if you try and shoot 4k60 video in warm climates.
at £1,699 body only in the UK it is £700 more expensive than an EOS RP, and sits only £200 cheaper than an EOS R6, or £300 cheaper than an S5II. Both far more capable and fully featured cameras.
In the US it's a $500 difference but I have trouble putting into real terms why this camera would be worth it for people. Not trying to be biased - I know this is an L mount forum, but I as a person who just recently went through an EXTENSIVE research process to figure out my next camera coming from a Canon 6d mk ii - these are my glaring issues with the camera:
-single card slot
-no ibis
-older evf resolution (the one the s5 got criticized for 3 years ago)
-tiny battery that dies after 60 minutes or so of recording 4k24
-no AF joystick
-micro HDMI and no external raw
-the high speed burst is limited to electronic shutter and 12 bit raws
-kit lens is a 24-50 4.5-6.3??
so I'm parsing all this through my filter of "okay who is this camera actually for?" It's an "entry level" full frame camera - which I believe is just marketing mumbo jumbo from yesteryear lead to insinuate that you somehow graduate from lesser sensors to the real deal.
For the casual photo shooter - who needs an ultra light, low battery capacity camera with no ibis that can shoot really fast e-shutter but not mechanical shutter? I'm seriously struggling to picture these scenarios where this is the optimized camera for you that justifies the price. I mean you could grab a used a6600, xt4, a7iii, or even r7 and get the card slots, ibis, and other features for less money. Or you could pay a couple hundred more and get the fuji xt5 with high res sensors 15fps mechanical burst, ibis, dual card slots, better evf, better battery and so on.
For video - I could see this being a great studio type vlogging camera - but in other applications we're running into some major hiccups. IF you want to use it for like action videography - well you'll need to mount it to gimbal or a tripod which is extra money. If you want to rig it up, well you have the micro HDMI to contend with and fewer video features than an s5 I or ii - and you'll still have the small battery, so then you're running external power to your rigged up r8 which is weighed down with a monitor and on a single card slot for the sake of having 4k60 uncropped with AF.
For vlogging - you're going to be applying a ton of stabilization in post which negates your cropless 60p to some degree.
For any pro work, the single card slot alone is a non-starter for most. For any kind of new pro photographer, you have the super expensive RF glass then to tackle because you're not shooting anything professionally on a 24-50 4.5-6.3. If you want to start out shooting weddings and are willing to roll the dice on the card slot, well then you can go out and grab yourself a 24-70 2.8 RF for $2200 - so now you have a $3700 kit with no data redundancy and your main advantage is your high burst and AF which then you're having to worry about light flicker and you're losing some color data in the compression. Or you're doing portraits and you want to save some money, so you have your 50 1.8 and now you've lose your weather resistance through the lens mount, you're shooting on a budget lens with not the best characteristics, and you'd probably have been better off with a cheaper camera and nicer lens.
Maybe it's an aspiring pro sports or wildlife shooter who can't afford the ultra expensive RF telephoto zooms so their option is the budget-friendly 100-400 5.6-8 - well there's no IBIS so you're going to be CRANKING that ISO which is really pushing the benefits of full frame anyways - why not just get the r7 with dual card slots and ibis for the same price that will even give you bigger reach on the same lens?
People are actually arguing back at me in camera discussions saying "no but you're getting great performance for the money" and I keep asking "performance for what??" Give me practical situations where these pros outweigh these cons for this dollar amount - maybe I'm not in touch with your average "entry-level full frame" shooter. To me, this seems to be a very niche camera for someone with very specific needs because it is so limited.
Thanks for the excellent analysis and summation, Nate. After I created my order for the S5ii, I waited until after the R8 announcement, just in case it had some intriguing and exceptional capabilities for its price point. Subsequently, it was a very easy decision for me to hit “send” on my S5ii order.
Exactly. These are the things you come to realise when you have a certain amount of practical experience. Despite some of the headline specs being pushed with the R8, there are too many weak areas when it comes to real world use. especially for the price. I see people claiming it is an R6II in a small body for half the price… It’s not, it has the same sensor, but the rest of the system is not designed to operate like an R6II.
Who is R8 for? Me perhaps. I am highly interested and debating to get one despite having S5 + few lens and having no EF RF glass.
For me,R8's key benefit is size/weight (461g) with FF IQ, Canon's color and AF in affordable price. Good for travel and not-sophisticated stuff. Pairing with OIS lens for usuable OK stablization. Worst part is Canon RF lens ecosystem. Only L mount FF with this small is Sigma FP with too many limitations (I have one).
If not for size/weight, paying $500-$700 more for S5ii and x are far far far far better choice in almost every aspect except 4k60 uncropped. The best $2,000-2,200 to spend on any camera right now, IMHO. L-mount non-Pro lens are much much better than Canon non-Pro lens too.
If I were in your shoes, I'd be looking at the xt5 in that case. Only 100g heavier which you're likely to make up in the lensing. Price will likely be net-cheaper since Fuji has affordable options. You gain much faster mechanical shutter, ibis, dual card slots, nearly double the battery life, better EVF, and the 4k 60 crop isn't bad iirc. The Fuji AF isn't as good but it's more than usable. The Hybrid Shooter on YT does fairly standardized testing and seemed to think it was good enough even for C-AF in burst. Not sure how the burst buffer compares. Being 40 megapixel, I think the IQ should stand up fairly well to a FF 24 megapixel sensor for the vast majority of applications. Just my two cents
The R8 is very attractive for entry level FF as is the Z5. I expect S5II prices to fall in line rather quickly. The S5IIX is aimed more at video so that may justify the higher price in the eyes of some consumers.
The size/weight of the R8 really caught my eye. But every time I get interested in an RF body I keep coming back to the abysmal lens selection. I wish Panasonic would make a body the size of the R8.
It's true. L lens are great but big & expensive. Non-L are no WR and fragile and zoom f stop is way too slow.
FUJI X-T5 APS-C at 2.000 euros; CANON R8 or LUMIX S5M2 preferable in many ways. FUJI XF lenses like 50-140mm big and expensive. FUJI more interested in their XH cameras. Of the three cameras expect CANON R8 as best-seller. But the small battery to save weight puts me off. Sony Alpha and Nikon Z have nothing to worry about; in many ways.
Full frame. For most people it’s not needed. APSC and MICRO 43ds, with all the latest software is fine. And cheaper. I have all systems and apart from maybe 1% of times I see no difference. But saying that my sport is not pixel peeping. I also take with a pinch of salt what all the experts say. ( 10 experts in a locked room and the result is 11 different answers ). Have people also noticed that this year’s greatest next year is,well, they aren’t as great. I think that Canon are the worst company for taking people for mugs.
The R8 has FAR better video specs than both the S5ii and R6, not even close. It is not only the sensor of the R6ii over the RP.
How do you figure that?
Reading the specs???
I'm looking at the specs and that's why I'm asking what you see that I don't. I see the r8 has no IBIS, no DCI, no open gate 6k, no raw, no full-sized HDMI, no anamorphic desqueeze, no spot metering, no waveforms or vectorscopes, no focus limiting, no focus transition, no live cropping, no MF assist "punch in," while recording, no second card slot, the battery only lasts 1 hour recording 4k24, it only weighs 460g so handheld is even harder to keep still, it has recording time limits, and no in-body LUT conversions.
The only things it gains are no crop in 4k60 and some more AF points.
I'm not trying to be a Panasonic apologist or anything - I just want to know your honest opinion on why this is "FAR better" than the s5ii for video.
We are all mugs for buying more expensive cameras depreciating at an alarming rate because of new models. Nikon Z6 / Z7 replaced with Z6II / Z7II. CANON RP? Fuji X-T3 replaced by Fuji X-T4. SONY A7RIII? You must pay attention and spot the winners.
And the winner is; S5 II
