Mads Bjerke
Do you have another GF lens to compare with?I don't take this as a demonstration of what either does. I take this as an example of a problem I keep having when using autofocus with this lens. I've made some wonderful images with this combo, but I keep having the AF fail in circumstances where I feel it should perform adequately or better. I don't expect perfection, but the lcd telling me eye detection hits during an afternoon sun photoshoot when shooting at something like 1/400 at f22, and when checking on a computer screen shows the whole person's face is blurry in all 4 shots, I have to wonder what is going on. Is it me? Is it a setting? Is something seriously damaged?OP, I think you need to completely start over and disregard this shot as any kind of example that demonstrates anything about the camera or lens. You have too many variables and possibilities of “what happened” that are not determinable at this point.
After today, I'm wondering if this is an issue of light and shadow for the AF point. Near pitch black environment today. Had the Q20II with me by chance. I was just haphazardly shooting because I expected it to be bad because of how dark the environment was, even with the flash. My expectations on critical inspection were very low, and well, see for yourself.
F5.6, one handed handheld, 1/100, 800iso.
This is how the raw looks with the flash fire.
text,text,
It is of course possible that the lens/camera isn't performing as designed.
If you leave all settings on the camera unchanged and then try another lens, you should be able to see if the lens is causing your issues.
If the problem persists with another lens you should look at the camera settings.
With a static subject the GFX cameras have very precise AF and you should have critically sharp images every time as long as you use sensible settings for shutter speed and aperture.
Make sure the IBIS is on if shooting handheld.
For reference, I shot with the GFX100 and the GF250+TC handheld and had perfect sharpness every time. A 35-70mm lens should pose no issues.
As I recall (I don't have the GFX anymore) I was always in AF-C (continues AF) and used back button focus. Just keep the button pressed in at all times (never let go) and take the image.
Use a small, but not the smallest AF square for consistently good results.
If you choose the smallest square the AF systems has little data to work with and could slip of the target easier.
If you are using a tripod, you should probably turn off IBIS (I say probably because I don't think I ever did and it was fine).
Mads Bjerke
__________________________________________________________________
www.madsbjerke.com
Create an account or log in to Instagram - Share what you're into with the people who get you.
www.instagram.com
