I've had it (CS2) for a decade - the free version. I could NOT "activate" it then, so the servers have been defunct for at least that long. All I do is click on "Do Not Register" each time I open it. It has not balked since it installed so long ago (in Win 8 then Win 10).Last time I checked (doesn't seem that long ago) it was, but apparently it's not any more? If it is, what key to use?
Registration and activation are not the same thing.I've had it (CS2) for a decade - the free version. I could NOT "activate" it then, so the servers have been defunct for at least that long. All I do is click on "Do Not Register" each time I open it. It has not balked since it installed so long ago (in Win 8 then Win 10).Last time I checked (doesn't seem that long ago) it was, but apparently it's not any more? If it is, what key to use?
I had a niggling feeling there was something I was forgetting.I've had it (CS2) for a decade - the free version. I could NOT "activate" it then, so the servers have been defunct for at least that long. All I do is click on "Do Not Register" each time I open it. It has not balked since it installed so long ago (in Win 8 then Win 10).Last time I checked (doesn't seem that long ago) it was, but apparently it's not any more? If it is, what key to use?
Actually, the only glitch I occasionally get is that it "forgets" the settings and color settings and just reverts to the default settings, with the color swatches etc. To get around this, I just set it all up how I like it and save a copy of the two files on the Desktop.
If this is of interest to you, here are the details (for Win 10):
C:\Users\User\AppData\Roaming\Adobe\Photoshop\9.0\Adobe Photoshop CS2 Settings\
Adobe Photoshop CS2 Prefs.psp
and
Color Settings.csf
Both live in that folder.
atom14.
Had another go at reinstalling. Not sure what I did wrong last time (either install path or neglecting to run as administrator), but now it all works, and there's no nag screen!OK, it's installed and working now. The only niggle is the nag (screen). I'm sure there's a way to get rid of that. I was able to before...
I'll see if I can find a way...
That is why I want it back. It does almost everything I need from photo editing software, and, just as important, I know my way around it - at least the parts I need - but as I've heard people say before, you could spend a life time learning the whole package.Ease of making selections, and UI eye-candy, aside, CS2 (and older) versions of Photoshop are still very powerful.
Not quite. I'll likely be using CS2 till it's no longer compatible with current Windows versions (or if I can still install Win 10/11).It's a shame Adobe render older software useless.
If you installed it without activation you have a 30 day trial.Not quite. I'll likely be using CS2 till it's no longer compatible with current Windows versions (or if I can still install Win 10/11).
That's not the case.If you installed it without activation you have a 30 day trial.Not quite. I'll likely be using CS2 till it's no longer compatible with current Windows versions (or if I can still install Win 10/11).
OK, that wasn't at all clear to me, especially with the title you gave this thread:I have a different version of CS2, that was downloaded from Adobe, with the specific purpose of getting around the activation issue. It was mentioned earlier on in the thread by Tom_N:
You need to read through the thread. You may have missed something.OK, that wasn't at all clear to me, especially with the title you gave this thread:I have a different version of CS2, that was downloaded from Adobe, with the specific purpose of getting around the activation issue. It was mentioned earlier on in the thread by Tom_N:
CS2 activation no longer possible? as well as some of your comments: I fully intend to complain, as I did pay a lot for CS2! ... I'll try Adobe support ... Would I be eligible for an upgrade? I did pay full price for CS2 ... I've been through this before, and know the outcome...
You had the activation-free version all along and forgot? Oh well, sounds like you're up and running so good on you.
Well yes, I'd forgotten that the servers were already dead when I'd installed it previously, and I initially thought something had changed between then and now, but obviously that was not the case!OK, that wasn't at all clear to me, especially with the title you gave this thread:I have a different version of CS2, that was downloaded from Adobe, with the specific purpose of getting around the activation issue. It was mentioned earlier on in the thread by Tom_N:
Well, that was one of the later comments I wrote here, after having gone through it all over again, so by this time I'd worked out my error.I've been through this before, and know the outcome...
Ta for pointing that out and reminding me.Registration and activation are not the same thing.I've had it (CS2) for a decade - the free version. I could NOT "activate" it then, so the servers have been defunct for at least that long. All I do is click on "Do Not Register" each time I open it. It has not balked since it installed so long ago (in Win 8 then Win 10).Last time I checked (doesn't seem that long ago) it was, but apparently it's not any more? If it is, what key to use?
A post by atom14 was chosen as the solution to this problem 693 days ago. Sometimes it helps to actually read the thread before you reply.Your best bet might be to contact Adobe directly etc...
I'll lock the thread to prevent recurrences.A post by atom14 was chosen as the solution to this problem 693 days ago. Sometimes it helps to actually read the thread before you reply.Your best bet might be to contact Adobe directly etc...
