So you want to see MTF curves for both situations?i wasnt very precise with words, i was trying to simplify. maybe i should say resolutionI don't think MP is a good metric for sharpness.the way teleconverters work they require lens with unresolved sharpness. meaning lens that is able to produce finer details then sensor resolution is able to read. otherwise there is no gain and it could be done just with digital zoom as well. so in general teleconverters has more chance to have gain with 50mp bodies. for 100mp sensor and 1.4x tc lens would have to be able to produce details on level of 140mp. 100-200mm maight not have it. but i guess it has at least 70mp and it is fine for 1.4 tc on 50mp body. anyone tested it on 50mp? do you know where to find lens tests with information about sharpness in mp? dxomark was giving that, but i think they didnt test fujinon gf lenses.
You can certainly use MTF curves to see if there's much energy above Nyquist.i wanted to know how large resolution it could fill with details. but probably MTF curves could be used to judge if it is "sharp" enough.So you want to see MTF curves for both situations?i wasnt very precise with words, i was trying to simplify. maybe i should say resolutionI don't think MP is a good metric for sharpness.the way teleconverters work they require lens with unresolved sharpness. meaning lens that is able to produce finer details then sensor resolution is able to read. otherwise there is no gain and it could be done just with digital zoom as well. so in general teleconverters has more chance to have gain with 50mp bodies. for 100mp sensor and 1.4x tc lens would have to be able to produce details on level of 140mp. 100-200mm maight not have it. but i guess it has at least 70mp and it is fine for 1.4 tc on 50mp body. anyone tested it on 50mp? do you know where to find lens tests with information about sharpness in mp? dxomark was giving that, but i think they didnt test fujinon gf lenses.
well, my math was wrong.for 100mp sensor and 1.4x tc lens would have to be able to produce details on level of 140mp. 100-200mm maight not have it. but i guess it has at least 70mp and it is fine for 1.4 tc on 50mp body.
Resolution is not an aerial metric. So all you need is 1.4x the resolution.well, my math was wrong.for 100mp sensor and 1.4x tc lens would have to be able to produce details on level of 140mp. 100-200mm maight not have it. but i guess it has at least 70mp and it is fine for 1.4 tc on 50mp body.
1.4x tc enlarage both dimensions, so it requires 1.4^2=1,96 more resolution from lens to not loose quality.
blog.kasson.com
100MP allows 1.4x the resolution of 50MP, limited by aliasing.on 100mp body it would have to be 196mp. on 50mp it needs 96mp.
that would mean if 100-200mm is sharp enough for 100mp sensor then it is also sharp enough for 50mp with 1.4x tc. if that is the case, i dont know.
let me calculate to seeResolution is not an aerial metric. So all you need is 1.4x the resolution.well, my math was wrong.for 100mp sensor and 1.4x tc lens would have to be able to produce details on level of 140mp. 100-200mm maight not have it. but i guess it has at least 70mp and it is fine for 1.4 tc on 50mp body.
Did you read the linked post above?let me calculate to seeResolution is not an aerial metric. So all you need is 1.4x the resolution.well, my math was wrong.for 100mp sensor and 1.4x tc lens would have to be able to produce details on level of 140mp. 100-200mm maight not have it. but i guess it has at least 70mp and it is fine for 1.4 tc on 50mp body.
8256×6192=51121152 (51 mp)
looks aerial, but im not the expert. any way it seem we agree to the numbers just calling it differently, 50*1.4^2 is around 100
Pretty much, if you want to find the total pixel count of the sensor. If you use sqrt(2) instead of 1.4 the numbers will come out closer. But pixel count is not resolution. If you have twice the pixel count, you don't have twice the resolution, although the product managers would like it if you believed that you did.half of it. anyway, my math was wrong when i said 70mp is needed. not 70mp (50*1.4) but 98mp (50*1.4^2). am i right with that?Did you read the linked post above?let me calculate to seeResolution is not an aerial metric. So all you need is 1.4x the resolution.well, my math was wrong.for 100mp sensor and 1.4x tc lens would have to be able to produce details on level of 140mp. 100-200mm maight not have it. but i guess it has at least 70mp and it is fine for 1.4 tc on 50mp body.
