You can download full size samples from
this link if you wish.
What a collection! Must be hard to "narrow my choice to only a handful that I would use on a regular basis, and to three lenses that I routinely carry in my bag for a half day hike."
May I ask which three
That's asking which of a shovel or a fork I would take. Depends on the job ! ;-)
As you know, buying lenses did cost an arm and a leg, especially in the medium format systems. So I couldn't resist some of the bargains or steals, when the digital turn-of led a whole herd of analogue lenses to the ditch. I already had P67 lenses from the film era, but as you can guess, photography became during flat days, opportunity for experimentation. However, when the conditions are right and you want to get results, you have to use the adequate tools to make the most of your day.
I always sought to reproduce the high definition of the large format film that I have used, years ago.
Depending on what camera and gear were available, I have had relative success with the Canon 1Ds3 and a Mirex for Mamiya adapter, since 2008.
Things got more serious with the A7R, used with a Rhinocam Vizelex for Mamiya and an adapter for Pentax 67. The lenses I was using at the time were the P67 55-100 and 90-180. Not a particularly light set. I had also a Pentax A35mm f3,5 on shift device for wider views, and the EF 100-400 I for longer reach, for assembled views also. The subsequent A7RII could be fitted to this rig as well, with the added bonus of a smooth digital shutter. I carried also the Mamiya 80mm 2.8 and 110mm 2.8, which were light, tiny and also very sharp.
I tried the Pentax 45-85mm and 80-160 (flare on the second at some settings), which worked well too, with a slightly smaller capture area. But since the A7RII was just so much sharper, it didn't matter, so they were my choice. Then I have used the Rhinocam Vertex with the same camera and lenses.
For people photography, I used some Canon lenses on the MC11 adapter and occasionally the "funtastic" Mamiya 150 2.8
Then got a used GFX50S a year ago, and a Kipon TS for Pentax 645. I used mostly the 45-85 and 35mm. The EF 100-400 II for longer reach. I also played a lot with the Rhinocam Vertex for GFX and a variety of lenses, both Mamiya and Pentax 645 (45-85) and P67. Some lenses are exceptional, like the Mamiya 80mm f2.8, the 110mm f 2.8. Both fill the crop. The P67 55mm f4 is also great. It is really fun to use that gear.
But the bells and whistles on the present forum led me to buy a second hand GFX100S with 45-100 some months ago. And since I had my content of shooting trial shots, I simplified my approach. So now, when I go into the woods, I take the 45-100, the 100-400 and the 35-70 for when I need something wider. Or for walkabouts with no particular reach needed, I swap the 100-400 for the GF100-200, which is lighter. I guess this is the answer you were waiting for, but mind that I seldom shoot single shots, so when I use the 45mm for 3 vertical frames panned, the resulting image is in fact much wider. For I still shoot in order to stitch in post, but only on a single row now that I have plenty of pixels. For tall trees within the forest however, I would take the Kipon shift and the Pentax 45-85 or 35mm on two rows, or the Rhinocam Vertex with those lenses, which can be also panned so you are not bound to a square format.
For casual people photography, I take the Tamron 45mm, the GF 110mm, and the GF 35-70mm. I have tried a Sigma 135mm 1.8 which works well on the Fringer adapter. Shots look great, but of course it is redundant with the 110mm. For portrait in casual photography, I also like the EF 85mm 1.2. The 45-100 should also be a good lens when there is enough light, but I haven't tried it yet for people photography yet, even if it has become my most used lens for static subjects. The great benefit of the GF lenses VS MF lenses on adapter, is the fast accurate focus and also the fact that I don't need to carry a tripod all the time, IBIS and IS combined are awesome. Well, if I haven't lost you at this point, you are likely ready and I wish you fun and enjoyment in your own quest !
Cheers
Paul
