Tamron FW update 17-70 and 18-300
Lettermanian
Nova Scotia, CA
As reported on FR, Tamron has released firmware updates for the 17-70 and 18-300; apparently to have their Vibration Control function when the camera's IS mode is set to "SHOOTING ONLY" while in AF-Continuous mode.
Support page with fw links: https://www.tamron.jp/en/support/
--"Be yourself. No one can say you're doing it wrong." -Charles M. Schulz
"I love mankind... it's PEOPLE I can't stand!!" - Linus
Thanks, I've updated my 18-300...hope to see some improvement.
I updated earlier today as someone posted that it was available for the 17-70.
It didn't fix the slow return to shooting mode from playback mode unfortunately.
I don't use shooting only setting so didn't really need to update but was hoping it might resolve my issue.
Thanks for posting
Paul
Thanks for posting
Paul
I updated my 17-70 this morning and though I rarely use AF-C or Shooting Only for IS, it seems to work as advertised: the VC is working when in those modes with the shutter button half-pressed.
Are you using the lens on an X-T1? On my X-T3 the shift from playback to shooting is a second or less.
Thanks for posting
Paul
Thanks for the reply.
I tried it on the xh2s and the xt4 with the same result, it's good to know yours is working better on the xt3 at least.
I'll check it on the xe4 later as that doesn't have Ibis, just in case it's an issue between the lens ois and the body Ibis.
Cheers
Paul
