In previous posts, I looked at 15 minute dark field exposures made with the Hasselblad X2D and the GFX 100S at ISO 800 and 1000 respectively.
There appear to be many people whose main use for long-exposure images is for subject blurring. Those people typically use neutral density filters and base ISO. I received requests to conduct the same sort of 15-minute exposure tests at the base ISO for both cameras.
I made two exposures.
https://blog.kasson.com/gfx-100s/long-exposure-noise-in-x2d-100c-gfx-100x-part-4/
Takeaway:
The X2D has more noise when measured in the raw file, but when viewed visually in a Lightroom developed image, the GFX 100S appears to have more noise. This is likely because the GFX spectra are biased towards lower frequencies, while the X2D ones are nearly flat.
Jim
- GFX 100S, LENR off, ISO 100, 14-bit precision, 15 minutes, 45mm f/2.8 GF lens and lens cap, f/32.
- X2D 100C, ISO 64, 14-bit precision, 17 minutes, 38mm f/2.5 XCD lens and lens cap f/32.
Takeaway:
Jim
