Not sure about my 100-400. Sometimes great, sometimes subpar...
Olyhal Regular Member • Posts: 157
Re: Not sure about my 100-400. Sometimes great, sometimes subpar...
Instead of buying a new lens, I suggest you buy the OM-1. It is that much better for bird photography. I have the 100-400 with the OM-1 and get a lot of useable shots, and as many will tell you too many shots.
I found spot metering does give much better exposures, and as a few have said, using the TC1.4 will reduce the quality of photos.
Howard T.
 Olyhal's gear list:Olyhal's gear list
Fujifilm FinePix X100 Olympus E-1 Olympus E-3 Panasonic Lumix DMC-L1 Olympus E-5 +23 more
Yannis1976
OP Yannis1976 Veteran Member • Posts: 6,309
Gary from Seattle wrote:
I see a variety of problems on most of these images. Those include, miss-focus, the fact that in macro (butterflies) the creatures are very large in the image and even slight movement of the creature results in a change of focus, too high of ISO on a few images (sun), and it looks like missing getting the exposure as close as possible to accurate so that PP adds noise or gives poor whites, and probably some other errors.
In macro of creatures like butterflies and bees expect a low hit rate because of the above mostly. Shoot bursts and expect to throw 2/3 of the shots away.
But I have no issues with butterflies or general macro. The issues are mainly with birds, especially at sunny days!
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
da7329 Senior Member • Posts: 1,322
It’s the body most likely.  The AF is just not that consistent on the em1’s or g9.  I have the 300 pro and using it on these bodies still AF can be hit or miss.  Comparing it to my D500 with a cheap 100-400  the D500 gives more in focus shots in a burst.  Better get an om1 to improve AF performance.  Pity it took so many years to get a MFT body with class leading AF performance.
DA
tammons Veteran Member • Posts: 8,140
+1
Mait
Mait Regular Member • Posts: 494
DA
I was wondering what could improve AF, get 300 pro for my em5III or get OM1....well maybe om5 someday and keep my 100-400 Oly.
I see many people are suggesting the second choice.
 Mait's gear list:Mait's gear list
Olympus E-M5 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Olympus M.Zuiko Digital 25mm F1.8 Sigma 56mm F1.4 DC DN | C (X-mount) +1 more
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
DA
As an OM-1 user, I'm not convinced that the AF is class leading.  It is very good and the subject detection is extremely good at subject detecting but I still get bursts that are less than perfect when it turns the detection into actual focus.  I'm more than happy with it but I'm sure there is room for further improvement.
RIAT 2022 departures https://photos.app.goo.gl/g7rDU1WiZuqxNjJy6
Farnborough Intnl https://photos.app.goo.gl/k2Xq8wiRqVPyeGkM8
recent 2022 birds here
https://photos.app.goo.gl/CJWqMLvHUC5PVG9G7
https://photos.app.goo.gl/RZNJ5A33H9KaT1QH7
https://photos.app.goo.gl/kxh57Ncexe9Gf9bA8
https://photos.app.goo.gl/Re2apxHeTvjfWwdX9
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Maybe I should have said close to class leading.  But class leading compared to older MFT bodes. I’m using older bodies but not for BIF or action.  Stills in dark wet rain forest conditions.  Weather sealing my main reason for using MFT in specific shooting conditions.
DA
victorav Senior Member • Posts: 2,751
You need to read wu Jiaqiu response earlier in the thread. The shots you're unhappy with were all taken in not great lighting conditions or shooting into sun it looks like.
DA
It is not perfect but it is class leading for mirrorless or close to it.
A friend has the Z9 and says they are about equal.
Yannis1976
Mait wrote:
DA
Well yes, that seems to be the most probable scenario. Waiting to see what OM5 will bring..
Promeneur Contributing Member • Posts: 621
I'm going to be the last one to offer you advice, but I have the PL100 - 400 and I know in my case from luck I occasionally take a few photos with this lens that I like to humbly think are quite good.  So, for me that rules out any thought that I have a "bad copy".  I've come to the conclusion that aside from also considering the light at the moment and atmospherics I have to perservere and work on my skills with this lens.  I find shooting with such a long focal length that I have a lot to learn, plus then there is also the learning curve in post for me.  You're way ahead of me, so I enjoy your photos and look forward to reaching your level even if there might be some perceived technical difficulties that I don't see and most people outside of this forum probably would never see unless they are professional photographers or accomplished enthusiasts!  Perhaps a new camera such as an OM-1 that matches the pro-level quality of the lens along with your skills will help you find what you are looking for.  For me you really nailed it in a number of the photos you posted in this thread!
Yannis1976
Thank you for kind words. I guess I might be asking a lot from such a long lens and atmospheric conditions are more important here than any other kind of photography.
Woody S
Woody S Contributing Member • Posts: 750
Take a look at the ISOs in the two batches of photographs, in the second batch you're shooting at much higher ISOs. That;s a bit of a problem in and of itself as well as the issues other have mentioned.
Yannis1976
Re: UPDATE!!!
5
Well, it seems lens can be sharp enough and I needed to change my technique. With the Fuji combo, since the 70-300 is smaller, manual focusing/correcting is easier. With the EM1/3+100-400 the whole combo is a bit bigger, the manual ring a bit further and I was trying to rely solely on the CAF. Wrong! As soon as I started focusing manually on the birds (correcting actually the initial CAF lock...), subjects started to look much better...
AshleyMC Senior Member • Posts: 2,228
Re: UPDATE!!!
Bravo!
Great images!
kbouk
kbouk Regular Member • Posts: 402
Re: UPDATE!!!
If you find that the manual corrections with CAF is about the same for all your photos maybe you can control it with a calibration inside menu Lens Data setting.
But unfortunately you can’t correct lens aberrations and fringing when you have difficult light in scene
Cheers
Costas
 kbouk's gear list:kbouk's gear list
Leica Digilux 3 Olympus E-M1 Panasonic Lumix DC-S1R OM-1 Olympus Zuiko Digital 25mm 1:2.8 Pancake +14 more
Zbynek Hromek
Zbynek Hromek Forum Member • Posts: 75
Re: UPDATE!!!
PL 100-400 is a very good lens, but condition for good results is aperture F8.
 Zbynek Hromek's gear list:Zbynek Hromek's gear list
Leica D-Lux 7 OM-1 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro +6 more
Zbynek Hromek
Re: UPDATE!!!
full size
Re: UPDATE!!!
Not really true as a blanket statement. It depends on the copy variation, and that is fairly wide.
DocBobB
DocBobB Contributing Member • Posts: 891
Re: UPDATE!!!
Pretty darn good I say!
Bob B
In use: Olympus OMD E-M1 mkii; OMD EM-1 mki; mZuiko12~100; m.Zuiko 100-400; Panasonic 45-175 PZ; Pan/Leica 25mm f1.4; m.zuiko 75-300; Rokinon 7.5 fisheye; Zuiko 50mm macro and EC14; Zuiko 50~200 ED, fl36, old e-510.
On the shelf: e30, EC20, 18~180, 14~42, 40~150, Zuiko12~60,
