DavidMillier
I recently acquired a Fotodiox Rhinocam Vertex rotary adaptor to adapt Pentax 645 lenses to Sony full frame.
The purpose of the gadget is to make stitching 4 full-frame images into a 46mm x 46mm square medium format frame as painless as possible, and by using a flat stitching approach, to preserve the character of the taking lens.
From my perspective, the theory is it is a much cheaper way to dip a toe in medium format than going down the GFX route. The final frame is a little larger than a square crop from GFX.
I hope my initial impressions might be of interest to anyone thinking of a convenient way to simulate larger than full frame (relatively) cheaply. Read on to find out how I got on.
This is the thing:
How it works
The narrow end mounts on my Sony A7r2 (other mounts available) and the wide end accepts Pentax lenses for the 645 film format (other mounts available).
You can see from the pic that the camera mount is slightly offset from the centre line of the adaptor. This facilitates flat stitching using rotation rather than conventional sideways shifting.
Benefits
The main idea behind this gadget is to make stitching more convenient and reliable than traditional methods.
You take a picture, rotate the camera 90 degrees, take a second shot, rotate another quarter turn and so on for four shots.
I've done plenty of panos by re-pointing the camera and some flat stitching using shift adaptors but for some reason I find the vertex's rotational approach more natural. I can do it automatically without having to carefully rehearse and think through the stitching movements. I don't forget where I've got to in the middle of the process. From this perspective it is an instant success for me.
For framing I'm experimenting with a cheap Helios clip on hotshoe viewfinder; first results suggest very approximate framing!
Stitching process
To my annoyance, my version of Lightroom 6 refuses to stitch these images. Maybe too old?
Fortunately I have PTGui which works fine and is quick. The frustration with LR is that LR outputs the stitch as a linear DNG (which I want), while PTGui only offers Tiffs and Jpegs. Tiffs weigh in at 650MB a frame which is a bit much. I've modified my editing workflow to deal with this by exporting the edited file as a 100% quality jpeg and deleting the tiff and source files. Not ideal, but necessary for me for housekeeping.
Results
The final stitched output pixel count is 2.5x the full frame sensor and supposedly equivalent to a 46x46mm format. A square crop of a 645 film frame in effect. Using my A7Rii, the final output size is 100MP.
First light impressions with the 55mm: I've shot my initial tests at f/11 and f/16 and the frames stitch perfectly, with the final result sharp corner to corner.
First prints
The maximum size print from my P900 is about 16" square with a narrow white border. I've only printed a couple of shots to date but looking at them, they look no different from shots from full frame, aps-c or even m4/3. This actually seems to be the main drawback with high resolution larger formats, real or virtual: An A2 print isn't big enough to reveal the extra resolution.
Availability and cost
Fotodiox is based in the US but I was able to get mine from a German seller through Amazon UK. This avoided complications with taxes and customs often endured with imports. Shipping was a few days. Total cost to me, £325.
I purchased a Pentax 55mm f/2.8 645 lens and a 150mm f/3.5 from ebay for £175 and £110 respectively. Cheap! I already own a Mir 38B 65mm f/3.5 Pentacon 6 mount and I'm awaiting for an adaptor to make its way from war-torn Ukraine. The 35mm 645 lens is more expensive and harder to find. I may get one later.
Although much more expensive than traditional spin stitching (effectively free), I was still able to put together a reasonable outfit of adaptor and 3 lenses for about half the price of the cheapest GFX lens, and of course, I already have the camera.
p.s.
Sharpening question: I printed a lot over the years, but mostly small A4 or smaller, occasional A3. I have no real idea how much to sharpen for A2 prints. Should I really go overboard with sharpening in an attempt to make the prints look different from lower resolution files?
Website: http://www.whisperingcat.co.uk/ (2022 - website rebuilt, updated and back in action)
DPReview gallery: https://www.dpreview.com/galleries/0286305481
Flickr: http://www.flickr.com/photos/davidmillier/ (very old!)
This is the thing:
How it works
Benefits
Stitching process
Results
First prints
p.s.
