Very Early beta access to Topaz Photo AI:Autopilot if you own DeNoise+Sharpen+Gigapixel
v0.10.0
Released September 8, 2022
No mention of fixing or even acknowledging the erroneous detection of "Severe noise" for scenes with foliage/water/other texture, which continues to be a problem that makes this application unusable for me. I have reverted to using only Sharpen AI. Wake me up when this is addressed.
v0.10.0
does deselecting 'remove noise' in PAI v0.10 apply NR to the textures?
v0.10.0
I don't know, but will try it. In any case it takes away any advantage of "AI" if I have to overrule it most of the time. I just tried the new 0.10 version, and they have either added or changed "severe" to "high". Here is a scene with water and foliage that was shot at ISO 200 and processed in DXO PureRAW with DeepPRIME noise reduction. PhotoAI deemed it to have "high" noise level after DeepPRIME! This is what PAI saw:
Image appears to be over sharpened. This may be why SAI shows High Noise
OK, same image from ACR instead of PureRAW, no sharpening whatsoever. Same verdict from PAI: HIgh noise.
Are you and others here who find problems posting them to Topaz? This is a free beta so in order to get problems fixed you must tell Topaz. Telling me here on this forum is good, but won't let them know and maybe get the problems fixed.
https://community.topazlabs.com/t/topaz-photo-ai-v0-10-0/34598/17
Henry Richardson
http://www.bakubo.com
Yes
As I mentioned in previous post I almost always send a layer from PS to Topaz app. When I apply what I need to save and return to PS. I can then tweak the adjustment. As I have always stated if we remove the human from the equation we are failing.
Well, isn't the purpose of "AI" applications to remove the human? Of course I can tweak the adjustments by Photo AI, but I thought the objective was for it to do the work by analyzing the photo. Otherwise what's the point? If Topaz can't do a better job than mistaking foliage for noise then they might as well pack it up.
Just a simple thought AI ICW the human should make the task easier. I believe AI is being over sold as the answer to tasks the human is either unwilling or unable to perform. I went to a Walmart the other day. In using the scanning system during checkout. I noticed the total was much higher than expected. In review of the receipt I immediately noticed I was being charged multiple times for the same item. In fact I was overcharged $37. If I would have relied on the amount the scanner told me . . . I could see if this was human error since this happened on multiple items and I had been using the scanning system almost daily at the store.
I am not sure of PAI since I have not tried it yet. I am familiar with Topaz products as I have used them often. I will not rely on making corrections in PAI. I know SAI and DeNoise allow the user to edit. However, I gain efficiency in final edit in PS.
May be when the auto industry achieves ADAS Level 5 we can sit back and rely on autonomy.
I am satisfied if the "AI" gets me close to a final result faster and easier than doing it manually. In this particular case, I ran your unsharpened version through PAI on auto and in spite of the "high noise" detection, PAI did a credible job on the photo without blurring away detail with excessive noise reduction.
I often lower the NR setting because I prefer less NR than some people, but I know many people who disagree with me. "One size fits all" does not really apply here.
I think that is how we should see AI. It gets you quickly to a good result that you can fine tune to your taste.
Ian
I'm a fan of Topaz so tried as you did, only I found that it did burr the leaves and smoothed out the ripples a fair bit . I will add that I imported the photo to PSE and accessed PAI from there. I couldn't see any problem with the original photo and expected PAI to not apply any filters.
Exactly. PAI sees things that aren't there. It needs an Autopilot category "No processing needed". And, as some have noted, it doesn't always apply as much noise reduction as it indicates is needed, so it also needs to match its categorization to its actions.
I ran this photo into TAI as a standalone app. Perhaps that accounts for the difference?
Here is the original:
Original
Original
And here is the TAI version on auto:
Topaz AI
Topaz AI
I compared all the ripples at 100% looking for blurred or missing ones, and didn't find any. In fact, it is a little oversharpened for my taste. I might have missed something, and I didn't look at all the leaves, so please let me know where the ripples appear blurred to you. I am using version 0.10.0 on Win 11.
George
Original
Original
Topaz AI
Topaz AI
Agreed, it looks pretty good. I also tried it as a standalone and got similar results; but it also stated that the noise was high, so it seems to be acting pretty much like the plug-in. Thanks for trying it.
Thanks, Henry.
I stored a few images which I corrected with various Topaz tools (Denoise/Sharpen) and start to compare them with the PAI - current version.
When I was first exposed to Topaz (not that long ago), Denoise and Sharpening were my aces and, in a few instances, they produced excellent results. At least a betterment compared to the originals.
This is an original 1984 JPEG:
The edit changed the white balance more than I was hoping for.
This is the correction using prior versions of denoise:
Mostly Denoise and some Sharpening
Now, Using PAI:
PAI - default setting
In this instance, the P in PAI did a better job than my M in manual.
The combination of denoise, face masking and whatever 'recipe' PAI uses may produce better (and faster) results than using the tools individually. I used PAI with its default settings. The original denoise make the result way too harsh (over sharpened?) and with some odd colors, especially in the faces.
I am not in a position to compare with other similar tools, but I sense that Topaz is going in the right direction.
These were my in-laws in 1984, attending the 400th Anniversary of Quebec City Foundation. My father in-law was a river pilot and he was really in his element here, as one can see his smile and joy.
Unfortunately, they have both passed away.
Jerome Boyer
This German guy (in English) does a good video using 0.8. He compares several photos using Photo AI to Denoise AI, Sharpen AI, and Gigapixel AI. I agree with him that unless Photo AI gets much better and offers more controls to use when the auto settings get it wrong then it is somewhat disappointing and not as good as the separate products.
I hope though that Topaz will truly get the results up to the level of the 3 separate products, while combining them in one and also providing more control when you want or need to override the auto settings.
Photo AI - The new wonder tool from Topaz? Short test for nature photographers
Henry Richardson
