Hi, everyone - to clarify, if you take a reading on a light meter, and then click the buttons on the light meter to stop up and down, it adjusts both the aperture and the shutter speed.
Perhaps I neglected to mention it is an incident meter: the camera is not involved at all.
So what I don't understand is, when I take a flash reading, and click the buttons afterwards, the light meter still adjusts both. Yet the shutter speed should not affect a flash-only exposure (unless it is outside of sync limits), so I was curious why it would do that in this instance.
Similarly, if I set a 'preferred' shutter speed on my light meter before measuring the strobe, if affects the aperture that it outputs.
I have a Polaris meter, and it doesn't work like that in flash mode. And this is verified by the user manual.
In Ambient Mode f/stop, once you take a reading it will change aperture and shutter speed as you press the up/down buttons.
In Ambient Mode EV, it only reports the EV and the up/down buttons have no effect.
In Flash Mode, you set the shutter speed and it reports the aperture for the combined ambient and flash exposure. The up/down buttons reset aperture to zero.
In Multiple Flash Mode, you have to hold the MULTI button down while pressing the buttons, and then press up/down buttons to change the number of flashes and it displays the aperture required for those flashes.
If aperture is changing as you press the up/down buttons, you are in Ambient Mode f/stop and are not measuring the flash (even if you fire the flash). The measurement is made at the time you press the trigger button.
