Box Brownie
I wonder if other users of the et-8550 could say if they have experienced the following?
With Epson papers gloss, Semi-Gloss and Heavy Weight Matt I have not noticed this....
I have some papers varying between 240gsm gloss to 310gsm Matt.
On the gloss and Semi-Gloss I have noticed one (possibly 2) witness mark lines along the print direction. It/they don't extend off the edges of the sheet but do make me wonder if it a feed roller leaving the marks? Note ~ the ink finish is fine, so maybe the rollers before the print head path are doing it.
On the 310gsm Matt I think the line is there but very much fainter compared to the other two papers. Though looking closely I can see slight scuffing of the ink in that area of the print...head 'hitting' the print surface?
Edit- this is on A4 and the line is approx an inch in from the LHS as viewed as the print appears.
Note ~ I see there is a thick paper setting in the printer settings, do perhaps that will mitigate what I am seeing on the thicker Matt paper.
Note ~ the printer is quite noisy when ingesting the papers through the rear feeder!
TIA for any user insights
