Hi all, I tried using my strobe for the first time today and found that the first shot I take on my camera doesn't trigger my strobe but the view finder then goes black and when I press the shutter again, the strobe flashes and that second photo is saved onto my card. This happened every-time, including when I am connecting my camera to the strobe via a cable or with a wireless trigger. Does anyone know why this happens? I am using a Canon 5D IV camera and Godox DE300 strobe.
Hi Sarah,
I don't have your system, but can only suggest the following:-
Trigger
1) what trigger are you using?
2) put new batteries into your trigger. Some triggers I believe don't use rechargeable, so check that you are using the correct type of batteries.
3) Check trigger firmware is up to date.
4) There doesn't seem to be channels setting on the strobe, so that is one problem out of the way. But press the "test" button the trigger to make sure it is firing the strobe.
5) What are your camera settings? Try iso200, f4, shutter 1/125 sec, put Strobe in Manual mode and set if to say 5.0 power. Put trigger in Manual Mode. Make sure HSS is off. Turn SLAVE off. These are setting where you should not get a dark image. The black screen maybe because of your shutter is too fast >1/250th or aperture too small e.g. f22.
6)
seems like can use Sync cable also USB (there is a hatch opening). see 5.42mins.
7) Also the strobe may need time to recycle before firing off, turn on the Sound so you know you are not triggering the strobe before it is fully recycled.
My gut feeling it is the combination of your camera settings and not waiting for the strobe to fully recharge before firing the next shot.
Sorry for a scrappy response, but it was quick. Others ppl do correct me or advise the OP.
