I want to adapt a Nikon lens to an L Mount camera. The lens has floating elements, so it is key that the mount registers the lens at the proper FFD, as opposed to going shorter to make sure it hits infinity.
Logical, but, for lenses designed to be used with film,
the aberrations introduced by the presence of a sensor cover glass are usually more than the aberrations caused by slightly wrong register for a floating-element lens. I.e., it's close enough.
Nothing's perfect and you'll be a lot happier if you accept that, but if you insist....
Novoflex, for example, seems to intentionally go short to do this.
Metabones and Kipon make the F to L adapter, but I am interested to see if people have see if people have any insights into companies that consistently make accurate adapters.
EVERY MECHANICAL DEVICE IS BUILT TO A TOLERANCE RANGE -- nothing is precise. I would argue it is good engineering design to err on the short side of the tolerance range and likely every competent adapter manufacturer is thus at least a hair short. Otherwise, they wouldn't hit infinity on cameras with the body flange on the long side of it's tolerance range. Tolerance ranges for body flanges are usually tight enough so that DoF will effectively hide the error, but not always. Incidentally, body flange accuracy was generally worse on DSLRs/SLRs because the PDAF sensor or manual focus screen was not quite in the same plane as the sensor or film (that's what PDAF microadjustments are about)... and film emulsions were relatively thick and roll film never lies very flat, making the film plane itself an imprecise thing. It's largely the thinner and flatter nature of sensors that makes these little errors more visible than they were with film.
The catch is,
it's actually pretty easy to add shims to many adapters to make them arbitrarily accurate for your particular camera body and lens combo. Some adapters are explicitly user adjustable, but shimming others usually isn't really any harder. Where this level of perfection matters (mostly in some very technical computational photography situations), I've generally used Scotch tape for thin shims and aluminum duct tape for thick shims. Obviously, adapters that are too thick need to be shortened, and that's much harder than adding shims....
One more note:
be sure you shim at the working temperature. Lens barrels expand and contract significantly with temperature changes. A large change in rear focus with temperature something people generally expect of long lenses, such as 500mm mirror lenses, and that's why many long lenses are explicitly designed to allow focus somewhat beyond infinity. However, short focal length lenses are much more sensitive to tiny changes, and the lens I own that has the greatest effective focus shift with temperature is actually my Laowa 10-18mm (in native FE mount). For example, I was recently shooting that lens in ambient temps ranging from about 75F down to 25F, and infinity can move to nearly the 3m mark over that temp range.
