D7500 with 18-140 in 2022?
Ashish07
New member
Hey everyone!
So i bought D7500 with 18-140mm back in 2019. Looking at everyone switching to mirrorless systems often urges me to switch to a mirrorless system. And in my country a Z6ii cost around $2000 that too body only. So what would you reccomend? Should i switch to a mirrorless system for doing travel, product, portrait, landscape photography?
I am so confused because $2000 is the maximum amount i can spend for it. And if i should continue with my D7500, should i invest on lenses and which lenses (budget for lenses $1000?
Regards.
Hey everyone!
Regards.
If mirrorless is what you want to do then fine - it’s up to you. The D7500 has a better AF system for sports/ action than any Z other than the Z9 . I have a Z6 for most things and a D500 for wildlife etc.
Since your interests do not seem to need fast action then a Z would be fine but you can do as well with an apsc dslr - it’s mainly about the lenses.
If you want FF instead and high mpx then it’s a Z7 vs D850 - again AFC faster on the dslr but Z has advantage of eye detect
Hey everyone!
Regards.
The D7500 is a fine, enthusiast-level camera. It's not that old and will give you many more years of excellent photographs.
In your case I'd keep it and add the following lenses:
AF-P DX NIKKOR 10-20mm f/4.5-5.6G VR - $310 rrp new.
AF-P DX NIKKOR 70-300mm f/4.5-6.3G ED VR - $400 new.
Your 18-140 is a very decent all-purpose zoom, and with the addition of a super wide and a medium tele you could cover a lot of bases.
I might also throw in the excellent AF-S DX NIKKOR 35mm f/1.8G prime as a low-light specialty lens, great for museums and art galleries, for another $200 and you'd still be under $1K.
All these lenses would be fine on a mirrorless DX body years down the road with an FTZ adapter.
Hey everyone!
Regards.
I agree. I have a D5600, but I bought the 18-140mm and also the 35mm f/1.8. They are a nice combo! I also have a 55-300mm for wildlife shots, which I plan to upgrade to a 200-500 f/5.6
Hey everyone!
Regards.
The Nikon 200-500 is terrific lens, especially for the price. It is a bit of a beast though but my guess is that you’re a lot younger than I am. :-D
The D7500 is a very capable camera. Shouldn't really limit your photography (based on your stated areas of interest). Personally, I don't think it's a good idea to switch to mirrorless just because everyone else is doing it. You should have a valid reason for the switch. Something like "if my camera could focus on eyes automatically, my portraits would be better". For me it was "I sure would like to use my old Minolta lenses again".
By last summer, I had been reading about the new Nikon mirrorless cameras and had become interested in seeing what the hype was all about. Much like where you are now. And, as I said above, those old manual Minolta lenses that I had saved for 40 years were sitting there on the shelf enticing me to use them. I had switched to Nikon back around 1990 and owned a D40 and a D7000 with quite a few lenses. When the Z5 went on sale for $1000, I decided that I could handle that amount of money to find out what the Z cameras were all about. I got the camera with the FTZ adapter which allowed me to buy the camera body only and use my old Nikon lenses on it. I also got a KF Minolta MD-to-Nikon Z adapter.
Two things were immediately obvious to me when I started to use my Z5. First of all, the auto focus does not work like it does on my D7000 (and your D7500). I won't go into the differences here (you can find MANY discussions on the subject here on DP Review) but figure on spending some time learning how to get the best performance when using AF. Secondly, I was somewhat blown away by the image quality. This was my first FF camera and despite never have been disappointed by the image quality of my D7000, I was amazed at the quality of my pictures, even at what to me were very elevated ISO settings. Your D7500 is sure to be better than my D7000 so the difference won't be a startling, but I think you'll be very happy with how your pictures look (once you get the focus business worked out).
If you have any interest in using old manual focus lenses, it's a no brainer. Get a Z camera right now. I have had more fun with my old Minolta MD lenses than I've had in photography for a long time. I had forgotten how much fun it is to put the plane of focus just where you want it using a 50mm/f1.4 lens. With the focusing aids on the Z5, focus is much easier than it ever was on my Minolta cameras.
I know you were thinking of getting a Z6 (the Z6ii I assume) and I can't fault you on that. However, you might be able to get a Z5 plus the 24-200mm lens for around the $2000 you are willing to spend. The Z5 doesn't give much up to the Z6 in features (image quality is virtually identical) and the 24-200mm lens is an outstanding walk around lens, adding a very useful couple of mm's on the wide end compared to your 18-140mm. The z6 and Z7 are likely to receive an update fairly soon, picking up some of the advances brought by the Z9 and when that happens, you could add a more capable mirrorless camera to your Z5.
Since you only have the 18-140mm lens, I'm not sure how much sense the FTZ makes for you if you end up getting a Z5 with the 24-200mm. If you owned other lenses, getting a FTZ seems like a very good idea. Just not sure it would be worth it to you. If you by a Z6 body, you'd need either the FTZ so you can use your 18-140 in DX mode (a not very attractive proposition in my opinion) or a lens to go with the camera. The logical, budget choice would be the 24-70mm/f4. You could probably pick up a used one pretty cheap. By all accounts it's a very good lens. Personally, I've never cared much for the 24-70mm range. 70mm always seemed too short on the long end. But a lot of photographers love the 24-70mm zoom. In your situation, getting a Z50 and using the 18-140 might actually be the best way to get into the Z cameras (you'd still need that FTZ).
Not sure my comments have been very useful. The takeaway should be that if you are getting a Z camera, you should do it because it will enable you to take better pictures or that it will allow you to enjoy photography more (as it did for me).
Bruno
Bruno
The only thing that i don't like about the D7500 (Idk if it happens to any other camera models as it is my first ever fully controllable camera) is that while taking shots from the low angle or a low perspective, i have to use the live view , which takes a huge amount of time to focus on a subject. With the OVF i am well off, but while doing street photography or any other genre , the ability to use the live view mode and capture the subject in its sharpest form is not possible, especially from a low angle of view.
Hey everyone!
Regards.
Yeah, the 10-20mm was often referred to me by many DX owners , especially while travelling because of its size and weight factor. Thanks!
Can you tell us what you mean by “a huge amount of time to focus”? I’ll admit that I don’t use live view much with my D7200 and D500 bodies but on the few occasions I have used it I didn’t find any major issues with it focusing, and in fact the contrast detection method it uses is probably a bit more accurate than the phase detection the cameras normally use.
On my D5600 the focus system when using the live view mode is much slower than when using the OVF, I think that's what he meant.
I mean the using the live view we cannot focus on a moving subject precisely, there is relevant focus breathing which slows down the whole process.
Apart from that, while shooting the from the viewfinder , the camera works very well.
Maybe the answer is simple as this:
I haven't shot with the D7500 but I'm convinced that a great camera too.
So if your budget is only sufficient for a D7500 with the 18-140, than that's what is it. The alternative is buying no camera and don't take memories.
Would this make sense?
Ah, I understand.
On the few occasions I have used Live View it was only for static subjects.
I also have a 7500. It is used with a 18-105 and a 55-300.
I need a longer lens then the 55-300. We have deer and elk within a few miles of town.
I have considered the Sigma 100-400 and the Nikon 200-500. What teleconvertor would work with these two option. I only have $900.
Hey everyone!
Regards.
Ashish: Have you consulted your local savant? Mine tells me the year 2525 is the one to wait for and be afraid of. So hold on to your precious photo gear until then.
Well, I'll try my best to keep using my DSLRs for the next 523 years, but it won't be easy. :-(
