This has sorta been covered in another thread. UP3218K
In case anyone wants more details, here are a few:
It was introduced in 2017. It's far from new.
It'll do 10 bit color at 7680 X 4310, but the refresh rate must be reduced to 48Hz. (Apparently, this is due to a bandwidth limitation of the pair of DisplayPort connections.) 60Hz is available in 8 bit. (The panel is a true 10 bit one.)
The inputs are a pair of DisplayPorts. Both are needed to get 7680 X 4320 @ 60Hz (48Hz at 10bit). Using a single port, that resolution is available only at 30 Hz (and 24 Hz).
HDR is unavailable at any resolution and refresh rate.
It has two memory slots for a hardware calibration. The required X-Rite i1Display Pro (Calibrite ColorChecker Display Pro) colorimeter is not included. The Dell calibration software is a specialized version provided by X-Rite.
The screen is high gloss, so take care to avoid reflections.
As far as I know, it is still the best 32" 8k monitor in existence. It appears to be the only 32" 8k monitor in existence. ;-)
(It's very nice.)
A setup hint: get it running with a single DisplayPort cable, then connect the second one. That may be needed to get the graphics card to use both DisplayPorts.
The link to the display "driver" (Windows .inf file) at the Dell support site is for the wrong file, unless you'd prefer the SDK (software development kit) for the monitor. Here's a direct link: UP3218k Windows driver
Sorry that I can't supply information for Mac or Linux users.
(It's very nice.)
