Sigma SD15 Camera - Please Does Anyone Have Raw?
Started 10 months ago | Discussions
Peter Slovakia
Peter Slovakia Contributing Member • Posts: 716
Does anyone happen to have some RAW from a sigma SD15 camera? I can't get a decent raw to see if it's suitable for enlargement - SuperRes in Photoshop. If the result was very good, the camera would be usable. But without processing a decent Raw, I don't dare buy it.
Does anyone have experience with this? Can anyone help?
Well thank you. Peter.
 Peter Slovakia's gear list:Peter Slovakia's gear list
Sigma DP3 Merrill Sigma SD1 Merrill Sigma sd Quattro +3 more
Sigma SD15
bizi clop
bizi clop Contributing Member • Posts: 640
Re: Sigma SD15 Camera - Please Does Anyone Have Raw?
 bizi clop's gear list:bizi clop's gear list
Canon PowerShot G2 Sigma DP2 Merrill Canon PowerShot SX50 HS
Peter Slovakia
OP Peter Slovakia Contributing Member • Posts: 716
Thanks, but not a single image usable here..
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
I am no fan of Adobe but I just put four up here for you ...
http://kronometric.org/phot/camera/SD15/
what you get is not what you saw ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
bizi clop
Hi, the jpegs are indeed missing, but the X3F files under the Sample RAW Images section are still there.
Or do you mean they're too blurry for superresolution or such?
Peter Slovakia
Yes, those RAWs are terrible
bizi clop
Yes, photographyblog's trademark are their terrible sample images.
Peter Slovakia
Thanks Ted, I'm going to try it now. Now, you could also compare the SD14 and SD15 cameras. How about them? Is there anything better / worse on any of them? What about colors and resolution in particular? I have SilkyPix on SD15, but I don't know if this program can enlarge the image from SD15 .. what do you think?
Thank you, Ted. Peter
bizi clop
I ran through Topaz Gigapixel one of their sample (x3f —> Kalpanika dng —> Gigapixel):
https://s8.gifyu.com/images/sigma_sd15_01.x3f2x.jpg
larryj Forum Pro • Posts: 13,086
HI Peter:  The SD14/SD15 cameras are similar.  The SD15 has the AFE (Analog Front End) which yields better colors right out of the camera, but has about 1/2 stop less DR. To get the best results for the SD14 required using a custom white balance to fix a strange green color cast on the images.
My wife is still using the SD15 and gets great results.  She makes 16X20 and 20X30 inch images for our annual Art/photo exhibit.  I have not used the super Rez in Photoshop on the SD15 files since I do not print larger than 20X30 inches.  Kathleen and I have some excellent images for the SD15 and could send you a few Raw files.  Some on the forum here say the SD15 is the best camera Sigma has ever made, maybe so!?
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
Peter Slovakia
Thank you Larry.
I can't imagine prints of 20x30 inches from such a low resolution. If possible, please send me RAW from SD15, best landscape and detail, if possible, I will try to enlarge the image in Ligtroom (SuperRes). Then, in my experience, I will be able to make a 16x24 photo. But I have no experience with the SD15 camera. Is it possible to print an image larger than 16x24 from the SD15?
The documentation states that SD15 can also be extended to ISO50 - is that true?
Thanks Larry. Peter
xpatUSA
The SD14 LCD is smaller and less number of dots. The SD15 LCD is the same size and number of dots as the SD1 Merrill. The SD15 has a bigger buffer. The SD14 uses the older CF memory cards.
The SD14 has a green cast especially in the JPEGs.
The resolution is the same.
I have SilkyPix on SD15, but I don't know if this program can enlarge the image from SD15.
I have never used SilkyPix. I have never enlarged any Sigma Foveon image.
Hi:  Peter:  Here are 3 SD14 images for me and 1 SD15 image from Kathleen.  These are Jpeg and all were used to produce 16X20 prints.  I processed all these images from the raw files using SPP and Photoshop.  I do not think you need super Res to produce prints this size from the SD15 or SD14.
If you think you need more info for printing large, just use the double size function when down loading the raw files to Tif or jpg files.
Enjoy!
larryj
xpatUSA
Yes. Also the SD14 with it's last version of firmware.
mike earussi Veteran Member • Posts: 9,440
Thank you Larry.
Thanks Larry. Peter
I've used both the SD14 and SD15 extensively and they both have their advantages and disadvantages.
IMO the SD14 produced the best looking photos because of all Sigma cameras it is the only one that can produce noise free shadows and skies when shot at iso 50:
https://pbase.com/mikeearussi/sd14_iso_50
I've never seen any digital camera by any manufacturer produce a file as clean looking as the SD14, they all have some noise.
The advantage of the SD15 over the SD14 is a 21 shot raw buffer and 2x faster processing times (3 seconds vs 7 for the SD14). The colors are also cleaner and more accurate out of the camera but not as saturated as the SD14, especially the yellows.
A possible (albeit minor) advantage of the SD14 over the SD15 is that the raws can be processed accurately in ACR whereas ACR will open the SD15 raws but they don't look very good.
I've owned four SD14s and two SD15s and none of them autofocused correctly, though I would get the occasional lens that was accurate on one of my bodies. Nor was the focus screen accurate enough to ensure accurate manual focus.
In order to ensure accurate focus you have to ship the body and all your lenses into Sigma repair so all the lenses can be calibrated to that one body.
This also means if you're thinking of trying to use old manual focus lenses on any Sigma body (except for the Quattro ones with live view) your focus will be hit and miss. Of course if you're using focus stacking then you'll be fine.
As for your primary question regarding maximum enlargements, that depends on how fussy you are and also the subject matter. For "soft and fuzzy" subjects like flowers you can go quite large, even the occasional 20x30, but for landscapes with fine detail then no.
I shoot a lot of landscapes but use panostitching in order to get the level of detail I require (for my taste), and the SD15 with its 21 shot buffer is excellent for that. I even taught myself to handhold a panostitch up to 20 shots and get useable results. I also learned how to focus stack flowers handheld again because of that buffer.
So I would say that the SD15 is the most versatile SD body of that chip generation.
I now use the SD1M both because of it's much higher resolution and its ability to fine tune the AF. I wish it had the buffer and processing speed of the SD15 and the noise free skies of the SD14, but everything with Sigma is a tradeoff.
BTW, here is a very good test of the SD15:
https://www.optyczne.pl/138.1-Test_aparatu-Sigma_SD15-Wst%C4%99p.html
I don't know how to post raw files on dpreview, but if you PM me I can try that way nor will it allow me to post a 16 bit tiff, but here is a jpeg you can work with:
SD15 with 70mm macro at f4
This is a single shot of a 47 shot panostitch that made a 146.6mp file.
 mike earussi's gear list:mike earussi's gear list
Sigma SD1 Merrill Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50mm F1.4 DG HSM | A Sigma 24-35mm F2 DG HSM Art +2 more
Peter Slovakia
Well thank you. Excellent workmanship.
Peter Slovakia
Thank you very much for the excellent summary of the main information about the sigma SD14 / 15 camera. I studied the test. It is detailed and very good. In conclusion, it is not worth investing in an older sigma camera. I will stay with the SD1M camera, for which I have set the lenses in the professional service AWH Prague (except 17-70mm macro OS). We have to wait for the new FF camera Foveon ..
Thank you all for your help. She helped me. I appreciate it. Peter
Abbazz
Abbazz Senior Member • Posts: 1,339
To me, the SD14 is the best Sigma DSLR. It is better than the SD15 because of its cleaner files. even though it requires a custom profile to get rid of the colors casts. This "teen generation" (SD14/SD15) also works seamlessly with Adobe Photoshop (for those like me who use it), while the SD9/10 are more tricky and the SD1 requires the Sigma plug-in or Kapalnika.
As stated by Mike in this thread, nothing beats an SD14 raw file taken at ISO 50. When taken with a good lens carefully focused (which for me means manually focused because I don't trust the autofocus on Sigma DSLRs), images can be enlarged to poster size while retaining their remarkable sharpness. The relatively small pixel count makes the files more mangeable and quicker to process, which I find very important: I am bored of these obese 50 or 100MPix images because I find the moderate increase in image quality is not worth the huge increase in file size, storage space requirement and processing time (incremental costs not matching the benefits).
In fact, when printed, I find it very difficult to find any difference between a good SD14 50ISO file compared to a good SD1 file taken in similar conditions with the same lens. So, why opt for the bigger and more difficult to handle file when the leaner file is just as good, if not better at the pixel level?
Cheers!
Abbazz
Peter Slovakia
Ted, thank you for the 4 RAW photos from the SD15 camera. I used SuperRes in Lightroom and sharpened them. It looks better than I thought it would be. So photos from the SD15 can be well enlarged and focused in Lightroom / Photoshop.
Thanks, Ted. Peter
Peter Slovakia
Thanks, Larry, for your pictures on camera SD15.
Ted he sent me 4 RAWs, which I processed and enlarged in Lightroom. Upsizing and sharpening works very well. It is possible to work with images from the SD15 camera in this way.
As I wrote in the post before, I will not buy another camera now. I'll make do with the SD1 Merrill camera. I'm used to its use and image processing. I don't want to complicate things it's not good for life. Or I'll wait for the new FF Siigma, which will definitely be.
Thank you Larry for your help. I wish you all the best and lots of beautiful photos
Peter
