Larry Rexley
in another thread I mentioned i thought the Rokinon (Samyang) 12mm f2 manual-everything lens I have seemed sharper than the Canon EF-M 11-22mm lens, and that I'd do a test one of these days.
This morning had good cloudy, flat lighting so i shot identical comparison shots of the city skyline with both lenses, processing the images using DxO PhotoLab 5 to do this comparison.
Details:
- identical manual exposures used for both lenses, all shots at ISO 100
- All images pushed +0.33 EV in DxO PL5, DxO Smart Lighting disabled, no contrast, brightness, tone, color balance, or other adjustment done (Exception: Roki 12mm shot at f2 had more exposure compensation, +0.67 Ev instead of +0.33 EV)
- Auto White Balance used for all shots
- Distortion correction disabled for all shots with both lenses (doing this appears to disable all other lens corrections for the Canon EF-M lens for exporting images, leveling the playing field for comparison)
- Maximum CA used for all shots (intensity 200, size 12, purple fringing correction enabled)
- Unsharp mask used for all shots: Threshold 0, radius 0.92, Intensity 200, Edge Offset 100 (exception: Edge Offset of 60 was used for both lenses in the f5.6 shots as the corners sharpened up for both lenses)
- Vignetting settings: Roki: at f2=70, at f2.8 through 5.6=45. EF-M 11-22: at f4.5=55, at f5.6=45
- Deep Prime de-noise used for all shots, Luminance 25
- All images exported to JPG at native resolution, max JPG quality (100)
f2: Roki 12mm at 1/1000s, +0.67 EV in post, vignette 70
f2.8: Roki 12mm at 1/500s, +0.33 EV in post, vignette 45
f4: Roki 12mm at 1/250s, +0.33 EV in post, vignette 45
f4.5: Canon EF-M 11-22mm at 13mm, 1/200s, +0.33 EV in post, vignette 55
f5.6: Roki 12mm at 1/125s, +0.33 Ev in post, vignette 45
f5.6: Canon EF-M 11-22mm at 13mm, 1/125s, +0.33 EV in post, vignette 45
Both lenses performed very well, and their performance wasn't very different by f5.6.
Overall I feel that the Rokinon lens appears to have better sharpness than the Canon lens at similar apertures... and allowing for the shallower depth of field for the f2 shots --- the Rokinon seems to render certain parts of the image sharper at f2 than the Canon lens does at f4.5.
The Canon lens at f4.5 had worse corner vignetting at f4.5 than the Rokinon did at f4, with both about the same by f5.6.
After shooting with the Rokinon for a few months, i found that I preferred to take it along instead of the Canon most of the time, since I liked its rendering so much, and it could do double duty as a good low light lens. Manual focusing isn't really an issue --- just setting it to the position I've determined to be 'infinity' is good enough 90% of the time, even at wide apertures.
Sadly the Canon 11-22 is now my least used lens.
Details:
