Need recommendations for BLN-1 Battery
Jhumroo
Dallas, US
I got a used EM-5 Mark II and a couple spare batteries for backup. Other than the OEM option, I see Wasabi, Kastar, Duracell, and some non branded choices online.
I’m looking for recommendations for good BLN-1 battery options. Please share what other EM-5 II shooters are using.
I've tried 5 different 3rd party batteries for my EM-5 Mark I and Mark II. They have all failed within a year and started to bulge (and stick in the camera).
Cameron Sino. Both for camera and several phones since 15 years. Never failed.
They don't seem to list resellers anymore. Here they're common, don't know in the U.S,
https://www.cameronsino.com/
I've always / only used Olympus brand. Total of 3 now. Never failed.
I've been through a lot of Wasabis in a GH2, EM5ii and EM1ii. I did have one (out of about ten) get bulgy, but it was a slow process so I retired it before it became a problem. I'm still happy with them - just bought a couple last month.
Every third party camera battery I've ever tried has had issues. Poor performance, short lifetime, swelling. I won't use anything but OEM batteries. Especially with smaller batteries.
I am very satisfied from Patona batteries. Never had an issue in 9 years.
L
Hahnel and Ansmann are both very good. Widely distributed in the UK at camera retailers and sometimes offered as a bonus with camera purchases.
FWIW, three ambassadors of different camera brands have recommended one or both as an alternative to manufacturers own.
Personally, I would avoid very cheap, non-branded ones.
An Ex-Pro BLN-1 worked fine with my E-M1.1 and Pen-F for four years. I scrapped it at the same time as my oldest Olympus BLN-1 because both seemed to have a reduced capacity. I’m using a Duracell BLN-1 now, but only since last November.
I've been using PowerEx batteries and chargers for the past couple of years with my E-M1 MK II and E-M1X cameras. Haven't had any problems at all in fairly heavy usage. I think I paid around $40 for 2 batteries plus a charger that runs off 120VAC and 12V. The 12V option is important as I'm on the road a lot and it's easy to charge them while driving. I could use an inverter with the standard 120VAC charger, but that's a much bigger device to haul around.
The ones I bought were not decoded so the battery level doesn't display a percentage, just several bars that are pretty inaccurate. Generally show 4 bars for a long time, drops briefly to 3 and then stop working.
I recently bought some fully-decoded BM-branded batteries for a Nikon Z-series camera and they work well. Haven't used them enough to determine how good they are.
I don't know if PowerEx makes batteries for the EM-5. If they do I would give them a try.
Well, this gets into the land of speculation. Note, while I've found a bit about batteries and such, fundamentally I am a software guy, so take what I say with appropriate grains of salt.
I've shot with an E-m5 mark I since 2014 and with the E-m1 mark I since 2016. Both of these cameras use the BLN-1 battery. In 2020 I've moved on to E-m5 mark III and in 2021 I bought the E-m1 mark II. The E-m5 mark III uses the BLS-50 battery and the E-m1 mark II uses the BLH-1 battery.
I've used a combination of Olympus batteries and third party batteries (mostly Watson). I've had all brands swell up and have to be replaced over time, including at least one Olympus battery.
My experience was the Wasabi batteries I used to use as my goto battery swelled up within a year. A lot of other forum members also had Wasabi batteries swell in the 2014-2016 time period. I don't know if Wasabi just had a bad batch, or fundamentally their BLN-1 batteries were flawed, but since then, I have not bought new Wasabi batteries. My Watson batteries seem to last about 3 years before swelling. I forget how long the Olympus battery lasted before it swelled, but figure 3-4 years.
There was this old thread (DPreview thread about BLN from 2016) about the quality of many of third party BLN-1 batteries that alerted me to the issue.
As I understand it, BLN-1 batteries use a slightly different chemistry from the normal 2 cell battery. It has a nominal voltage of 7.6 volts, while the current generic battery has a nominal voltage of 7.4 volts (and the older batteries were 7.2 volts). This means that chargers meant for one nominal voltage might not properly top off the battery with the others. A secondary effect is the battery with the lower nominal voltage will appear empty sooner since the camera was designed for the higher nominal voltage (the camera uses the voltage to just how much capacity remains).
I now use the charger with the same branding as the battery, i.e. I use Watson chargers for the Watson batteries, and the Olympus charger for the Olympus batteries. I use Watson batteries since that thread mentioned that of the third party batteries Airmel looked at, the Watsons were the best, and many of the others were junk. For my secondary batteries for the E-m1 mark II, I went with Kastar batteries (Watson did not have BLH-1 batteries at the time or they were sold out).
So a lot of people say they only use official Olympus batteries. Unfortunately we get into market realities. The E-m5 mark II was the last camera Olympus made that used BLN-1 batteries. It has been replaced with the E-m5 mark III that uses the BLS-50 battery. Similarly, the E-m1 mark I camera has been replaced with the E-m1 mark II/III, and E-m1x cameras that use the BLH-1 battery (and the new OM-1 uses the BLX-1 battery).
In addition, to it being awhile since the last BLN-1 camera was released, in that time period, Olympus closed its factory in China and moved operations to Vietnam, and then Olympus sold the camera division to OM Systems. Both of these incidents might make the company officials re-evaluate what older products should be dropped.
My speculation is Olympus stopped producing new BLN-1 batteries a few years ago. A similar thread within the last month (on a different forum) had people nothing that the 'new' Olympus BLN-1 batteries they recently bought were built in 2019. A lot of the FAQs for lithium-ion batteries say that you should start replacing these batteries around 5 years after the battery was made (it doesn't matter as much how you use the battery, but when it was made). This means even if you buy a bunch of 'new' BLN-1 batteries now, likely you will need to start thinking of replacing them in 2-3 years time. This means picking the best clone battery.
You should also start monitoring your batteries, and if it gets harder to put the battery into the camera and take it out, properly dispose of the battery and replace it ASAP.
Had a few non genuine BLN-1 batterys swell but still buy them due to pricing......did see someone here asking recently about Duracell BLN-1 batterys they had found which as we know is a well known brand.
Not sure if they are genuine Duracells or knock offs but might be worth trying, i think they are around half the cost of the OEM.
Im going to look for a couple myself to try.
Thank you for the detailed response I have an E-M10 in which I used DTSE batteries and two of the four swelled up in about a year and the third one after about two years. So, I’ll be closely monitoring any 3rd party batteries I purchase for that. Based on the responses in this thread I have a few options to check out.
Appreciate everyone who responded.
Just a pixelpusher with a love of photography
I purchased a Duracell for my Pen f unfortunately it didn't work for very long no more than 12months, It shows the flashing warning bulb in the Olympus charger now. so I assume it is useless. Purchased a used Olympus battery which is fine.
Similar experience here with 3rd parties. I'd stick with OEM. After shelling out enough on 3rd parties on the em10, em5ii, and em5iii, I could have bought a few OEMs and still be using them (still using the included batteries in each of those, and all the 3rd party batteries I have are already not holding a charge or bulging, probably about 8 batteries).
But as I said earlier, it is likely that Olympus/OM stopped making the batteries 2-3 years ago. For now, that is probably ok, but I would imagine in 2-3 years time, you would want to switch to clone batteries, assuming you are still using the camera.
