Just curious, has anyone switched from Canon R system to the Nikon Z system?
If so, a couple more questions:
1). How did the IBIS compare? (Specifically IBIS of the R6/R5 vs. Z7II).
2). How does the subject tracking compare? I’ve heard and read that there are a few steps to initiate the subject tracking on Nikon Z’s…(not sure if this has been updated in a firmware or if there are real-world work-around with function buttons).
3). How is the customization?
4). Is there a fast/simple way to change ISO?
5) how have you found the weather-sealing to be?
Thank you!
Not direct comparison, but I am fortunate enough to run multiple systems. My R body is the Ra and RP and previously had 1D’s and 5Ds. I have the Z9. I also have Fuji X/GFX and spent extensive time with my cousin’s A9.
1) Personally, I find the Canon grip to fit me more like a glove whereas the Nikon Z9 grip doesn’t “feel” as good initially but provides a more secure grip with better stability. I have size 7-7.5 gloves. I would prefer the Nikon if I had sunscreen on my hands/sweat, but I think I would probably prefer the Canon after a long day.
2) I may get flamed here, but I find the Z24-70/2.8S to be worse than the EF 24-70/2.8 adapted to the Z9 with a Fringer adapter.
Initially, I thought that the A9 had faster AF for “close focus, tele range” but the Z9 is able to single out the eye where the A9 can only see a face and it can see a face when Sony doesn’t see anything.
But my keeper rate with the Nikkor 24-70/2.8S is lower than the EF 24-70/2.8 II adapted to the Z9. I think for video, the Z lens is better and potentially at 24mm the Z lens is better. But at 70mm, the Canon glass is better.
All of the reviews that put the Z9 behind the R3 and A1 are likely attributable to the focus motors in the 50/1.2 or 24-70/2.8 between the different systems.
3) IBIS is superb on the Z9. Pairing it with the EF 400/5.6L, I get very effective viewfinder stabilization. The viewfinder image is more stable than the Olympus 150-400 @ 400 (800mm equivalent) on the M1X. It’s not apples to apples due to the 2X difference but that tells you how good the Z9 is because the Olympus 150-400, M1x is considered one of the very best OIS/IBIS combinations for any system.
I have read somewhere that a z7-2 competed favorably with the E-M1 Mk III where the E-M1 is able to maintain very good sharpness to ridiculous multi second exposures but that the Z7 II was actually able to beat the E-M1 for “excellent” sharpness by 1/3 or 1/2 stop.
4) Subject tracking on the Z7 isn’t as good as the Z9 or Canon’s. The lens motor choices for native Z glass definitely contributed to that perspective and I have not tried EF glass on Z7.
For customization, ISO, weather sealing, all are pretty reasonable. LensRentals felt the Z7 and R5 were similar although it did seem like the R5 was marginally better in the seals having some suction during disassembly.
