You can make one. I did. The details about the connector are here: http://www.nikonweb.com/forum/viewtopic.php?t=15I bought a dcs 420 on ebay, but it doesn't come with a charger, what should I do, I don't want to buy a charger, is there any way to modify it?
14V 3AThank you, SQLGuy
What kind of power supply specification or AC power supply are you using?
I'm worried about the risk of burning out the board
There are places that sell them, like these guys: https://www.impactcomputers.com/mi2815-760.htmlHi,
Yep. That would do the trick. Any old notebook PC power supply with the right output and the correct plug. Actually, that's what Elpac made for Kodak in the first place.
Stan
So, Google says this translates to:你好,我找到一張顯示電路圖的圖片,當我丟失了插頭的中間部分時,機身中間的插針有用嗎?
資源
Nikon's timers have the same plug
尼康的定時器有同樣的插頭
Further down in the link you shared it shows all the functions - serial data, color wheel motor signal, remote release, and power.I'm just curious, what function does the Kodak socket represent? Because I'm not sure if the cable I bought can be used correctly for charging
Yes. That cable should be fine.
