THETA X 11K Speed - 3 seconds per image. It's fast!
jcasman
Member
San Francisco, CA, US
It takes roughly 3 seconds to complete an 11K image in this first test by theta360.guide developer community. Compare to 8 seconds for the SC2 at 5376x2688.
X image resolution: 11008x5504 - 3 seconds or 5504x2752 - 2 seconds
SC2 image resolution: 5376×2688 - 8 seconds
Z1 (JPG): 6702x3360 - 3 seconds
Reference: https://api.ricoh/docs/theta-web-api-v2.1/options/file_format/
NOTE: Z1 has a considerably larger image sensor and can also take RAW images. Test above is only with the JPG image.
If bracketing, can it burst the bracket to RAM and process/save later?
If not, then 3 seconds per image is not fast, it is EXTREMELY slow.
from the video, that's for and 11k still image, in a dark room.
So the exposure probably needed to be long
and apparently it was doing "image stiching" no idea what that means in this case
btw, 11k: 11008×5504 => 60,588,032 pixels
more information here:
https://360rumors.com/theta-x-review/
specs:
Sensor Sizet wo 48mp Sony IMX586 1/2.0 inch sensors
Photo resolution 11008 x 5504
Video resolution
5760 x 2880, 30fps
3840 x 1920, 60fps
Bitrate120mbps
Live streaming :Yes 3840 x 1920 30fps
100mbps
Shutter speed:1/16,000 to 60 seconds
ISO:50 to 3200Stabilization:6-axis gyro-based image stabilization
Interval shooting: yes (intervals: from 6 seconds to 1 hour)
Microphones monaural
the link also mentions some cons, which for some will be deal-breakers. So, this will depend on what you intend to use it for
