Hi! Can I use cheap canon paper like canon Photo Paper Glossy? It’s because I want to experiment with the printer but don’t want to use expensive paper and the closest profile I can find on the printer is the Photo Paper Plus Glossy II, can I use this profile?
There are loads of various coatings utilized for making shiny paper, some of which will ruin the fuser in a laser printer and some of which function admirably.
At the point when I initially began working prepress, we would purchase reflexive paper uniquely intended for laser printers. I appear to review it was preferably costly a few times more over normal printer paper. (It's made by Hammermill; you can observe it at strength paper stores, and I bet you can most likely think that it is online as well.)
The lustrous paper made for inkjet printers truly isn't great for laser printers. Ideally, you need to dismantle it and scratch the gunk off the fuser rollers. Thinking pessimistically, you want to supplant the entire fuser get together.
You can stack plain paper or photograph paper. If you slice plain paper to a size of 5" x 7" (13 x 18 cm) or more modest to play out a preliminary attempt, it might cause a paper jam. We suggest Canon real photograph paper for printing photographs.
