Helios 44M 58mm F2 mounted on EF-M42 adapter with Viltrox EF-M1 adapter on Panasonic Lumix G9
Pierre-Philippe
New member
Hello all,
I recently acquired a Panasonic Lumix G9 on Ebay which I find really good and entertaining for both Photography and Video. I upgraded it to the latest firmware (2.5)
I am going to use it mainly with the Panasonic 14mm F2.5 and the Olympus 12-40 F2.8 pro I also got on Ebay. Results are very promising.
But I also have various Canon EF lenses, because I am originally a Canon EF shooter and still have my old 6D with a few Canon EF lenses.
On top of that, and that's the topic, I also have a couple of old M42 lenses, i.e. an Helios 44M 58mm F2 and a Jupiter 85mm F2 . Both lenses are vintage manual lenses which I used on the Canon with a small M42-EF adapter.
I also used them a bit with another MFT camera I got a couple of years ago, an Olympus E-PL8 which I still like as a "shirt-pocket" camera. Adapting the lens to the Oly by combining a Viltrox EF-M1 adapter to mount the Helios lens (itself being fitted with the M42-EF slim adapter) I have been able to take pictures with the stabiliser of the Oly camera active. Its menu system allowed me to manually input the focal length for proper stabilisation.
I was hoping to do the same with the Panasonic Lumix G9... unfortunately the IBIS goes bonker with this combination. The camera believes that the focal lens is 2115 mm (two thousand one hundred and 15 millimeters) long !
When I go to the Stabilisation menu, the item to choose the focal length is greyed out.
Because of this, as soon as I start pressing the shutter the viewfinder shows me a very jerky view. The pictures show motion blur unless I use a high shutter speed. Clearly the IBIS goes bonker.
My theory is that the Viltrox adapter reports some random value for the focal length to the camera. The camera, having received this value, does not let me override it (the Olympus camera on the other hand lets me do so).
The EXIF data of the photo shows the lens as "EF1-5535mm F1.4". This is similar actually when I use the lens on my Canon and looks at the data in LR, the lens comes up as "EF-1-65535mm" there.
Do you think there is a way to make the Lumix G9 understands that this is a 58mm lens ?
Why don't you just get a cheap M42-to-MFT lens adapter? You don't need autofocus or electrical contacts with those old manual lenses, so the Viltrox seems like overkill.
That would be my theory too.
Hi, here is my Helios 44M with Lumix GX7. works great
Do you recommend a particular adapter to achieve this ?
Not really, there is a wide variety of suitable adapters. Some may be made with greater precision than others, but I'm not convinced that one adapter is better than another just because it is a few dollars more expensive. It's important that an adapter allows lenses to focus on infinity, but these days, I think they all do.
This seems to be a popular cheap one at only $6.99 (I've also seen it offered for three times this price), and it can be adjusted to center the lens (but I don't know how important that is in practice) : https://www.ebay.com/itm/162050532013
This is a nice 'professional' looking one at $25.64, still quite affordable, and the seller is emphasizing its precision and quality: https://www.ebay.com/itm/384006629368
And there are many others! I guess it comes down to your budget and your ambitions. If you just want to experiment a little with your old glass, a cheap adapter may suffice. If you want to do some serious photography with high-quality lenses, I'd opt for a higher quality adapter.
K&F has a good reviews and it is all aluminum
