JeremyB2
Leading Member
My RX10 IV will be arriving soon. I intend to buy a filter which I will keep on the camera at all times to protect the lens as I use a lens hood infrequently.
I have no knowledge at all of filters but have done some research on this forum and elsewhere. I don't think at this stage I want a CPL filter because I do very little video work. My question is whether I go for a clear protective filter or a UV filter. I appreciate the benefits of UV filter in certain circumstances, but are there any negative aspects bearing in mind that I will be keeping the lens on the camera all the time. I assume it's worthwhile buying a reasonably expensive filter to reduce the possibility of it affecting image quality.
Possibilities………
Sony VF-72MPAM 72mm MC - Protector
B+W 72mm Clear Glass XS-PRO Digital Filter - Protector
Hoya 72mm HD3 UV Filter - UV
There are of course other manufacturers and other filters within each manufacturer’s range. Comments will be much appreciated. J.
Edit: I should of course also have mentioned a ND filter which is the one I meant to refer to about use for video.
Possibilities………
