I bought the SA 2i almost 3 months ago and have used its baseline capabilities to get some pretty decent 30 second tracked images of a variety of objects using my Canon M6ii and a used Tamron 150-600 zoom. I am trying to decide whether to invest the time and energy into figuring out how to use the more "advanced" capabilities of the SA (e.g. the SA App, the WiFi capability, the shutter release capability, the Firmware Upgrade, and the Advanced Version Firmware, etc.) The supplied user manual is not great, and it doesn't spend a lot of time explaining why the user might want to use these capabilities. For example, I have a intervalometer, so is there any advantage to using the SA's shutter release capability? I've read a couple of negative comments regarding the App and the WiFi capability that has made me reluctant to spend a lot of time researching all of this. Just wondering if anybody out there is using these capabilities?
Thanks in advance.
Howdy,
Since I unfortunately dropped my intervelometer in the grass while carrying my equipment back to the car one night (never found it) I always use the SA 2i app and internal shutter control. It really isnt difficult once you know how. Ive never had issues with it, though ive found your phone needs to remain on (and connected to the SA of course) for it to work. if you turn off your phone screen, it wont tell it to stop the exposure. Just turn off the autooff display setting on your phone and makes sure its charged (brightness setting on the lowest, its dark out anyway...)
Download the app from their website, then flick the SA to the app mode. Disconnect your phone from your home wifi and search for wifi connections, the SA should appear with a weird name. Connect to that.
Open the app, in the top it will say connect to device, click that. if you are connected to the SA wifi this will connect the two. From there, all you have to do is enable slidereal motion (top right corner button) and then open the shutter control option in the advanced menu and select how many exposures and how long each should be for. You have to connect your camera to the SA with a cable (differs depending if you use sony, canon, nikon etc). press play and sit back.
Theres also a polar alignment tool I find helpful, since polaris isnt exactly north, its slightly offcenter. The tool in the app will show you where polaris should exactly be for perfect alignment.
I always do a quick 5 minute test of everything to ensure it is charged and functional before heading out.
