I have a couple of situations where I want to attach an Arco-stye clamp to wide flat surfaces. All the clamps I currently own are tightened with a knob, which require riser blocks to use.
With lever-style clamps, are the lever arms slim enough to open and close while laying flat?
Hello Jack,
In the past I have done something similar to what it sounds like you are doing, using both RRS lever equipped clamps, with those at least you should have no problems.
But I am curious, are you sung the ARCA-Swiss type QR system to attach a camera directly to those surfaces, or are you using the A-S QR system between a tripod head and the surface?
If it the latter situation, my advice is that you consider a quick-disconnect system like the Area-Swiss Quick-Link (
https://www.bhphotovideo.com/c/product/1513554-REG/arca_swiss_802320_quicklink_set.html, or the iFootage SeaStars Q1 (
https://www.bhphotovideo.com/c/product/1560246-REG/ifootage_seastar_q1_quick_release.html
or if you want keep everything In the ARCA-Swiss type , but want use a screw knob, there is the Large Tripod Head Quick Disconnect System from Kirk Photo:
https://www.kirkphoto.com/tripod-mo...arge-tripod-head-quick-disconnect-system.html
Yes, I'm looking to interchange heads and such. I'd considered the Kirk unit, but couldn't decide if I liked it, so I got some Chinese ones on the Amazon brand iShoot. While I was waiting for them to arrive, I saw Kris Hejnar has a selection in several sizes, as well as what SunwayFoto calls "Discal" clamps in various sizes too.Typical Hejnar quality: Excellent. The iShoot ones arrived and they are nice also, if a bit lighter and more Spartan finish.
The main source of my question is, I have a Manfrotto Multi-row pano rig, and sometimes I shoot with the leveling base; sometimes without. I have dovetail plates under both the rotator and leveler. I'd want a clamp for the top of the leveler, but it's 100mm in diameter. None of my knob clamps can be mounted to it.
What I think I am going to do is mount a dovetail to the top of the leveler, and then use a two-sided clamp to hold them together. The dovetails raise it a few millimeters from the surface, so there's clearance for the knobs. I got a SunwayFoto for another purpose, and I like that it's just one piece of aluminum with two jaws, rather than two clamps screwed back-to-back.
