tundracamper
What a great idea. Why hasn’t Nikon already done this? How long could it take to develop such an item? An afternoon?Hopefully Nikon can create a Flash Cable similar to the SC-29 with a green light
Maybe no one uses Speedlights anymore as there is currently no new MILC speedlights made by Nikon.What a great idea. Why hasn’t Nikon already done this? How long could it take to develop such an item? An afternoon?
I have not seen anywhere that Z autofocus system is sensitive to blue light. Auto focus sensors on Z system are located in the green photosites, therefore sensitive to green light.Maybe no one uses Speedlights anymore as there is currently no new MILC speedlights made by Nikon.What a great idea. Why hasn’t Nikon already done this? How long could it take to develop such an item? An afternoon?
Found a good article on Speedlights and Z cameras
Best part is:
"Z system autofocus sensors are sensitive to blue light, not red."
So they instead add a Green Light Hmmm.
Also now I remember my discussion with the Nikon Rep last week
He told me that the DSLR cameras focus system is separate from the Sensor hence it does not rely on the Sensor to figure the focus like in the Z cameras which do not have a separate focus sensor. (If I remember this all correctly, I should have written it down after I talked to him)
Good to know, must be a typo in the article. I've not had enough time to read every article on the Net in regards to Z cameras as I only started about 2 months ago with my first Z.I have not seen anywhere that Z autofocus system is sensitive to blue light. Auto focus sensors on Z system are located in the green photosites, therefore sensitive to green light.
I've read it in the Thom Hogan's book.Good to know, must be a typo in the article. I've not had enough time to read every article on the Net in regards to Z cameras as I only started about 2 months ago with my first Z.I have not seen anywhere that Z autofocus system is sensitive to blue light. Auto focus sensors on Z system are located in the green photosites, therefore sensitive to green light.
What Z bodies do not support for CLS?The same here with a Z6ii. I wish I'd kept my D750 for flash work as it worked perfectly with my SB800(s).
The main reason I've stayed with Nikon since 2005 is their (former) full support of their Creative Lighting System. I've spent a lot on Nikon's flash equipment, only to see the mirrorless bodies slowly abandon support for CLS.
How well does the LED work on the SB500 can it help auto focus in dark? I know it is not Green light but if it was bright enough?had to buy an SB-500 to get my Z6ii to trigger the slave units.
My comments regarding the SB-800 with a Z camera had to do with its inability to act as a trigger flash with the CLS, unlike their DSLRs. Not to mention that with my old D750, the SB-800 could not only trigger remote CLS flash units, but at the same time also act as a standard TTL flash unit together with the slaves.HRS,
I’m not sure what the SB500 is that you mentioned and I don’t know what you mean.
The SB800 sits high, well above any of my lenses mounted on my D810 or D500, including the 24-70 f/2.8. The only time I ever see a flash shadow is at 24mm, at the very bottom of the image. The focus assist lamp always allows the camera a perfect focus even in complete darkness. I get almost instantaneous flash images from pushing the shutter to the capture
Neither D500 and or any Nikon DSLRs after that. When I used D500, I had also to buy SB500 to control off camera flashes.There still is (some) support, as I mentioned, but not for all the SB-800's capabilities.
For instance, my D750 could use an SB-800 as a trigger flash for CLS slave units, but no longer. I had to buy an SB-500 to get my Z6ii to trigger the slave units.
That's interesting, and news to me.Neither D500 and or any Nikon DSLRs after that. When I used D500, I had also to buy SB500 to control off camera flashes.There still is (some) support, as I mentioned, but not for all the SB-800's capabilities.
You still can use SB800 for CLS but not as a commander. BTW D780 or D850 cannot us SB500 as a commander. and all of them do not have built in flash.That's interesting, and news to me.Neither D500 and or any Nikon DSLRs after that. When I used D500, I had also to buy SB500 to control off camera flashes.There still is (some) support, as I mentioned, but not for all the SB-800's capabilities.
For being such a "flagship" camera for Nikon, I'm surprised they dropped SB-800 CLS support. Yet, my non-"flagship" D750 from two years earlier fully supported CLS, as did my D70 from 2005.
I don't have a D500 to try, but your experience seems to contradict Nikon's Speedlight Compatibility Chart:Neither D500 and or any Nikon DSLRs after that. When I used D500, I had also to buy SB500 to control off camera flashes.There still is (some) support, as I mentioned, but not for all the SB-800's capabilities.
I am talking about control from the camera. But you can control from SB800 itself.I don't have a D500 to try, but your experience seems to contradict Nikon's Speedlight Compatibility Chart:Neither D500 and or any Nikon DSLRs after that. When I used D500, I had also to buy SB500 to control off camera flashes.There still is (some) support, as I mentioned, but not for all the SB-800's capabilities.
https://nikonsupport.eu/europe/images/6312/SBCC_en.pdf
