michaeladawson
I've done a couple of house real estate interior shoots recently and have the possibility of getting into it more frequently.
For the most part I'm pretty well set on equipment. I've got a Z7 and Z7ii. I have the Z 14-30 and 24-70 f/4. Plus I use the 19mm tilt-shift with the FTZ. I've got a closet of DSLR cameras and lenses as well, but I'm happy with the Z bodies for this purpose.
The one issue I have run into a couple of time is that 14mm is not as wide as I would like for the shot I want to get in a very tiny space. Let me be clear that this has not been a major problem. The realtor was pleased with the photos. This is more of a personal quest. If I had a 14mm shift lens I would probably be all set. But alas...
I'm wondering if any of you out there that have shot real estate interiors (or similar) have any suggestions on a lens wider than 14mm that is sharp enough edge to edge for this purpose. I don't shoot wide open so I do get the benefit of sharper edges by virtue of stopping down to f/5.6 or f/8.
I'm open to any suggestions. Manual focus is fine. F-mount on the FTZ is fine. Even a 14mm or 16mm F-mount lens might be fine if there was a wide enough image circle that I could get a little shift out of it with an F to Z shift adapter.
Anyone have just the ticket for me?
