Erik Baumgartner
- Messages
- 10,236
- Solutions
- 39
- Reaction score
- 14,241
The built-ND filter in the X100 cameras stinks, sorry, but it just does. It is very prone to (blueish) veiling flare/loss of contrast in any sort of bright light and, unless you're using it low light (where you wouldn't need it), it's pretty much worthless, IMO.
I noticed, using only the ND in the x100vi, a blue-ish mist and bad IQ over darker area’s. It seems it effects quality ( negatively) in darker areas as well. No extra editing done! But…
I did a simple test with a photo with a lot of contrast and i did see really a lot of differences with or without the ND turned on. Only difference was shuttertime. ISO on both 125, all settings the same except with nd: 1/13s without 1/160s, both with undercomp -1/3 stop.
ND variant looks really bad.
In the lighter less dark areas the difference were also noticable in the clearity of colours but not soo bad as in dark areas.
The last one is obvious with ND on.
is this worrieng? I do not like it and this is really not what i hoped for. I liked the idea to have a build in 4 stops ND. It seems to be useless. With my b+w nd filters there is always sone distortion in colour / whitebalans but quality is always oke. I have never seen this.
If you really need an ND for extended exposures or video or something, I highly recommend getting a high quality screw-in ND to use instead. Otherwise, just let the Electronic Shutter automatically take over at higher shutter speeds (The leaf shutter has its own issues at higher shutter speeds). Unlike the newer cameras, the earliest models had no ES option and a very slow leaf shutter, so an ND made sense. Personally, I've never run into a situation where I would need to use the built-in ND with my V.
Easy to see the effects on image quality with the built-in ND vs. the electronic shutter here.
