Overrank
- Messages
- 7,916
- Solutions
- 14
- Reaction score
- 4,435
A quick "review" of the Kodak Pocket Instamatic 60, one of my favourite 110 cameras. It was introduced in 1972 and was the top of the line of the Kodak cameras. Apart from the Trimlite 48, and possibly the Ektramax, it was the best Pocket Instamatic camera that Kodak made. I wouldn't like to guess how many weeks wages it was at introduction, but now it can be purchased for <£10 (which is lucky, see later).
The 60 is a rangefinder camera with auto exposure and is metered for "slow" speed 110 film, which isn't actually specified but it probably between 64 and 80 ASA. Currently available films that I use, i.e. Lomography Tiger, are 200ASA, which it will be overexposed, which is OK..
One of the problems with the 60 is that it needs a "K" battery, a special battery that is no longer made. However a few years ago I noticed that someone is the USA was making 3d printed K batteries which you could use with hearing aid cells. I bought one, and my first 60, and then used it for a while. However, one problem was that the k-battery replacement I had would need rebuilding every time you replaced the batteries (which was often as they were zinc-air batteries).
3d printed K-battery (second type I tried)
So then I saw a new K battery replacement which was screwed together rather than Sellotape. Again from the USA. I purchased one, waited for it to arrive and then put it in my 60. Which promptly broke - the shutter just stayed open. Not knowing if it was the battery or the camera I bought another camera (as I said they are very cheap) and confirmed it was the camera.
So if you're looking for a high quality 110 camera which isn't a Pentax Auto 110 or Minolta Zoom, is readily available and very pretty, but requires a custom battery that costs about the same as three cameras, then I highly recommend the Kodak Pocket Instamatic 60 !
Some photos, adjusted for contrast, but otherwise unchanged
