Hi, I am thinking about getting a 200-600 and selling my other telephotos (the 70-180 Tamron and 100-400 Sigma). I would be primarily getting this lens for wildlife - as I assume most do - but am curious how it performs with compressed landscapes. Comments or examples would be super appreciated.
100-400 range is quite normal range in landscape photography, it’s often used for separating distant subjects. Take pictures of fine details in nature. In woodlands it can give a magic like feeling due to its compression, especially if the in hilly areas and you get there when there is still fog in the fall. It draws in the mountains instead of miniaturising them like a UW. So it’s very useful.. 400- 600mm is typically in the long end, not many landscape photographers go that long, there are a few but tend to use teleconverters as the 200-600 is borderline too big and heavy unless you see yourself driving in close proximity to the location, or if it’s the only lens that you take with you. I find the Tamron 150-500 a bit more manageable as it’s 400g lighter, it doesn’t go to 600mm but personally 500mm is plenty, but personally I would find anything exceeding 1.2kg to heavy for landscape, but then I also walk there.
My preferences is a 100-400, a 70-200 is actually long enough in most cases but the extra reach dos give you more framing options, so I prefer 100-400, especially as the lenses tend to weight and cost the same (mostly because the 100-400 is variable)
I have seen some crazy one who dragged a 400 or 600mm fast prime with then, so if one really wants to it can be done
