Quattro SPP exported raw, higher contrast?
tohereknowswhen
Leading Member
I've read here that the "portrait" color mode has the least contrast. I really like how the jpegs from the camera look when using this mode.
However when I open them in SPP a loooooooot of contrast seems to be added. It also seems to have some boosted saturation?
Here's a jpeg:
And here's the same image exported from SPP with no adjustments:
Any thoughts on what may cause this? Any workarounds?
And yes I know the obvious solution to this is issue is to just shoot jpeg :D
Generally speaking, the raw-to- JPEG conversion software in-camera is not the same as that used by SPP
Secondly, when SPP opens a raw image, the review settings may not be the same as the in-camera settings. Even if the review setting are "the same" the conversion will still be different.
Not really a "workaround" but I always have my in-camera JPEG settings at sRGB and zero contrast, etc.
I always open a raw in SPP with the original X3F settings, not last settings, nor any other option.
Not familiar with SPP6, maybe others can say more.
Here's a jpeg:
tohereknowswhen,
Probably due to settings in SPP. Change to suit whatever effect you want get.
S
Yeah I figured as much. I open it with the original X3F settings for what it's worth.
Here's a jpeg:
tohereknowswhen,
S
Yeah, it must be the case. Dropping the contrast to -2 and then -5 on portrait color makes it looke closer to the JPEG:
Good.
What color space in-camera sRGB or aRGB?
What JPEG settings in-camera (saturation, etc)?
Pedantry is hard work, but someone has to do it ...
I'll take a guess the Detail setting in SPP could be affecting the contrast. What setting is Detail on?
If you provide a screen shot of your process it might help.
