"S/D qh" Ted?!? lolThe colors from the S/D qh look nicer.
Hi, Scott, "if you can't beat 'em, join 'em!", eh?"S/D qh" Ted?!? lolThe colors from the S/D qh look nicer.
Yes I noticed it too. Almost like scan lines on a CRT!I don't find either of them particularly useful in color, but Merrill works better for high-ISO monochrome since it doesn't have (variable) AFE banding.
"In both cases, I set ISO to 5000 and let the camera decide upon aperture and shutter speed."Why did you expose the SD Quattro H image 1 stop less?
--I think there would still be a big difference, but maybe no so alarmingly bad, if you had exposed the photos the same amount. In fact, why not just expose both at [the same f-number] for the same amount of time at the same ISO setting?
All that said, I'm amazed how clean the fp image looks with no noise reduction at ISO 5000. I wonder how the fp-L would fare in comparison.
You are right. As I said, I let the cameras decide.Why did you expose the SD Quattro H image 1 stop less? I think there would still be a big difference, but maybe no so alarmingly bad, if you had exposed the photos the same amount. In fact, why not just expose both at f5.6 for the same amount of time at the same ISO setting?
Theses a Raw then saved in JPEG using SPP only. No Noise Reduction appliedHey Roger, are these OOC jpegs or what? I
Yes it doest seems that the latest versions of SPP do a pretty good job on high-ISO raw files from Quattro cameras these days.
Good ideaI haven't tried really high-ISO shots, but I did try some medium ISO shots, and it went pretty well. I guess I should do a comparison between what I can get with my SD Quattro H files fom SPP and some other program, using exported 16 bit TIFF files and the OOC jpegs, just as an interesting blog post for SigmaPhotoPro.com.
ExcellentI could call it "Processing High ISO Files With SPP."
No I do not. PhotoScape X reads my XF3 files up to the SD1 but I like SPP better although both programs are free.Do you use any special denoisers, like Neat Image or a special plug-in for Photoshop or Lightroom?
The FP-L has more MP but also has a AA filter where the FP has less MP but does not have an AA filter. To me the FP is cleaner, sharper.Why did you expose the SD Quattro H image 1 stop less? I think there would still be a big difference, but maybe no so alarmingly bad, if you had exposed the photos the same amount. In fact, why not just expose both at f5.6 for the same amount of time at the same ISO setting?
