I picked up this flash along with my A6400, my first e mount body. My only complaint with the flash is the very tight fit on shoe, it’s quite difficult to get on or off. Does anyone have tips on making this process a bit easier?
Yeah, definitely aware of that but thanks for checking. Even without locking the ring down the flash is very tight on the shoe. I have seen others comment on this but not much in the way of suggestions for addressing it. This thread mentions it, for instance:Ok, dumb question: Do you know about the disk part of the flash that you rotate to lock it on? Aka part of the flash that you need to rotate. As you rotate it it moves away from the camera to make it slide on/off and rotates towards the camera to lock on the camera.
I have a different Godox flash and it goes on/off my a6000 easy as long as I rotate the disk. My old Canon flash also goes on/off my a6000 without an issue as long as I rotate its lock disk.
That’s good to know, maybe it will resolve over time for me as well.i think i remember feeling that the 350 was a bit tight too compared to the 685 when i got them. its not the case anymore, i guess it loosens (erodes) up over time
Yeah, same with the a6400. I'm going to leave it on the body for several days and see if things loosen up at all.This is the first flash gun (which might itself be ab outdated term) I've had in decades, so not much to compare, but, a6500 and... I find it, Hmmm, not just tight, but a bit awkward to fit. The more hurry, the longer it takes!
Which would you rather have, a tight fit, or a loose fit? My first Sony camera was a NEX 5T (still have it), and the lens mount was very loose with all my lenses. When I upgraded to the a6300, I thought it was a very tight fit with all my lenses. After thinking about it, I was glad my lenses fit more securely.Here’s another report of this issue:
https://www.dpreview.com/forums/thread/4561439
I also have a RX10M4 and getting the godox on and off that body is pretty easy. But the A6400 is a very tight fit in comparison.
The issue is the amount of force one has to apply to remove the flash. And tightening the ring isn't even needed, the flash is on there so firmly.Which would you rather have, a tight fit, or a loose fit? My first Sony camera was a NEX 5T (still have it), and the lens mount was very loose with all my lenses. When I upgraded to the a6300, I thought it was a very tight fit with all my lenses. After thinking about it, I was glad my lenses fit more securely.Here’s another report of this issue:
IMO, I would think you would be happy your flash has a tight fit, but YMMV.
Which would you rather have, a tight fit, or a loose fit?... ... ...Here’s another report of this issue:
Hmmm... Tight, I guess.IMO, I would think you would be happy your flash has a tight fit, but YMMV.
